REmoving wheel cylinders
Old Feb 25, 2006
dazzdillinger's Avatar
dazzdillinger is an unknown quantity at this point
It's a small line, about 10 inches long that connects from the main brake line into the wheel cylinder. What is it called? How do you remove it from the wheel cylinder? Am trying to and the brake line is twisting on me. Do i spin the bolt 360 degrees or wiggle it back and forth?
Old Feb 26, 2006
streetglower's Avatar
it is also part of the brake line assembly. Now to remove that nut from the wheel cylinder, you need to use a flare nut wrench. I have been in the same situation before and have found normal wrenches dont work.
Old Feb 26, 2006
tfnaaf's Avatar
BLDNPSI Mod
Sometimes if you live in RUST country it will require a little heat to break the nut lose from the line as well as from the cyl
Old Feb 26, 2006
just out of curiosity, does anyone know what size SAE flare nut wrench is equivalent to a 10MM metric flare nut wrench for that brake line nut?
Old Feb 26, 2006
tfnaaf's Avatar
BLDNPSI Mod
None
Old Mar 3, 2006
Sae and metric are incompatible. Using a wrong but similar looking wrench will round off the bolt.
Old Mar 3, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
agreed. and btw THE CLOSEST you can get is a 3/8 (f you if my fraction is wrong, thats why I love Metric)
GolNat
Suspension DIY
May 12, 2022 06:49 AM
159
Jul 5, 2015 09:54 PM
Jun 2, 2015 11:54 AM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
