knocking sound in the suspension
Old Feb 15, 2002
silverman's Avatar
silverman is an unknown quantity at this point
Whenever i drive my car over speedbumps, i hear a knocking sound as the front wheels come down from the bump. The dealer diagnosed it and replaced the two front schocks in front under warranty but then it is still there- like a metal knocking sound. Whatever speed on the speedbumps, it still knocks. Another problem is a rattling sound around the area of the front drivers' side wheel, still the dealer couldn't find it. Damn too irritating even running through smooth roads. No modification on the suspension though in case you might ask. Need advice on this, any of you had the same problem??
Old Feb 15, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
hmmm, wierd, not lowered?, no rims that could be rubbing?
Old Feb 15, 2002
Shawn02's Avatar
Shawn02 is an unknown quantity at this point
My car is in the shop right now for that very same problem....it happened to me alot in cold weather...like a clunk clunk sound. Well, it was the springs, they were coiled too tightly, they are both replaced, and they are going to re-align the front end tomorrow and i'll pick it up. They also fixed the various rattles. I suggest you bring some service bulletins when you visit the dealer, and show them you won't the their BS. Luckily, i have a great dealer thats honest and does good quality work everytime.
Old Feb 15, 2002
silverman's Avatar
thanks man!
Old Feb 16, 2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
I had the same problem after having some H&R springs installed. After taking all the units apart again here is what I discovered. Inside the bottom of the strut tower there is a metal spring seat that the top of the springs sit in on the front end. Mine was rubbing on the right front and making the same noises you described. I spun the seat around and now it doesn't rub. On the rear one of my gromets was in crooked and that is now fixed too. If you spring seat is rubbing in your strut well you should be able to see the rub marks. Hope this helps.
Old Feb 16, 2002
silverman's Avatar
thanks!
Old Feb 17, 2002
Dakker's Avatar
Giggity Giggity
Dakker is an unknown quantity at this point
Sweet!! Thats why mine do that, and you are right, I wouldn't have read any further but you said that it only happens in cold weather and thats what happens here.
Old Feb 22, 2002
Quiksilver's Avatar
Quiksilver is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
I HAVE THE SAME PROBLEM AND IT'S STARTING TO P*SS ME OFF. I STILL HAVEN'T GOT TIME TO GET IT TO THE DEALER SO THEY CAN CHECK IT. IT HAPPENS A LOT WHEN BRAKING IN SHORT DISTANCES.
Old Feb 25, 2002
TheEnemy's Avatar
TheEnemy is an unknown quantity at this point
I'm pretty pissed too, my dealer is trying to **** me around and not look.
But now that I see that it is common, I'll give him a little peice of my mind. It seems to happen to me mostly on short choppy bumps in the pavement. Thx for the help.
Old Feb 25, 2002
oatmeal's Avatar
oatmeal is an unknown quantity at this point
my car is going in to the shop soon for the same problem but my is more like sqeeking noise as it come down from the the bump.....hopfully dealer can fix it
Old Feb 25, 2002
streetfxracer's Avatar
streetfxracer is an unknown quantity at this point
ok guys i have a simmilar prob the supencion rattles during all that but it also rattles when it rains heavilly here what do yall make of that i need help with that so if you could or maybe i should have the dealer look at it or maybe the guys who fixed my car didn't fix it right from the accident help would be appreciated
Old Feb 25, 2002
Marker02's Avatar
Marker02 is an unknown quantity at this point
mine use to and still do, and i found out that it was the whole spring itself moving or twisting inplac. i havn't got it fixed cause i ddon't know what to do about it. has any one had this problem or any one know what to do? thanks.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 28, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
I have the same problem with my left front suspension, and it was a bad strut. Dealer replaced it under warr. Get your struts checked out, if you still hear that thud sound going over bumps. It may not be the springs like familyMan said.
Sep 26, 2023 06:44 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
15EXCoupe
Jul 30, 2015 12:59 PM
mrohitredd
Jul 21, 2015 09:26 AM
mokkush
Jul 14, 2015 04:05 PM
