It won't start...bad starter?
Old Jan 13, 2006
reytito's Avatar
So i'm leaving for work and i turn the key....nothing happens. I check the battery, its fine. I check fuses for ignition, starter...they are fine. Could this be the costly product of a starter that needs to be replaced?? Local honda dealership quoted be around $500. I can do it myself for a fraction of the cost, but I need to know 100% that its the starter. Ideas/insight would be WONDERFUL! THanks
Old Jan 13, 2006
streetglower's Avatar
well you need to do some testing before you deem it a bad starter.
Now how did you check the battery? Did you try to jump start the car? Also did you have the battery tested?
Also do a visual inspection under the hood first.
Also does it just click when you try and start it or does it not do anything?
You may have a bad starter relay, a bad range switch or interlock switch depending on if you have a manaul or auto tranny.
What you can do is if you have room, havent ever checked with our car, but a trick I learned is take a screwdriver and touch the metal part to the battery terminal at the starter and run it accross to the s terminal of the solenoid, if the engine starts, then the starter is fine, you have to check for another problem in the circuit. If it doesnt start, you may have a bad starter. You can also use a jumper wire from the battery to the S terminal with the s terminal disconnected. this is the manauls method. The method I suggested is something that can be done if you dont have the proper tools.
If you need any other help, let me know.
Old Jan 13, 2006
pon55's Avatar
You do a good job,unfortantly most peps don't post the correct list of problems!
PEOPLE, please, if you want help be specific as to what is happening.
car wount start;
engine rotate Y/N
rotates= this way\no = this way
this would really help all!
(general-not this post)
Old Jan 14, 2006
reytito's Avatar
Well guys, get this...I go home last night and decide to give it another try out of a gut/instinct, and it starts up no problem. Drove it normal today on some errands and no problem.
The only explaination, and its very unplausible to me, is that it was Friday the 13th, and there was a full moon.
Can anyone offer any explainations? I'd liketo avoid this in the future if at all possible. Thanks
Old Jan 15, 2006
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
could be a loose connection somewhere? maybe a loose ground?
did u recently disconnect the battery for any reason?
...when u said nothing happens....
i'm assuming:
lights didn't turn on
engine didn't even try to start
Old Jan 15, 2006
pon55's Avatar
Dirty battery terminals (bad connection)
Old Jan 15, 2006
reytito's Avatar
When i said nothing, I meant the engine did nothing. No turning over, etc. All lights/electonics still worked just fine, so it's not the battery terminal.
Old Jan 15, 2006
pon55's Avatar
AH-ha info
Std or auto?
Old Jan 15, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
I still think you should have the battery checked, especially if the car did start the next time you tried it. It takes a lot more to run the starter than the radio. it doesn't need to be completely dead before the starter won't turn over. another thing to throw into the mix is the alternator, if its not working right, its not charging the battery, which in turn may not have enough juice to start the car.
Old Jan 15, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
Originally Posted by pon55
AH-ha info
Std or auto?
lets hope its not an STD hahahah
anyway, if its an auto maybe the shifter wasn't in park all the way or something.
if its a manual maybe the clutch sensor is a little sluggish. idk.
Old Jan 15, 2006
pon55's Avatar
thats what i was getting at!
Old Jan 15, 2006
reytito's Avatar
not an auto. my manual doesn't have a clutch sensor switch. I did a conversion.
Old Jan 16, 2006
pon55's Avatar
check to wires that should go to that switch.
Old Nov 23, 2017
Max1990's Avatar
Max1990 is an unknown quantity at this point
Re: It won't start...bad starter?
It is frustrating when your car won't start. You are turning the key and... nothing happens. Almost every car owner has experienced this. Is it the Battery, Alternator, Spark Plug or Starter Problem? The Common problems of Honda Starter as follow you can check:
1. Dead or Weak battery
2. Poor electrical connections at battery terminals
3. Park or Clutch Switch is Broken or Misadjusted
4. Security System Error
5. Damaged Starter
6. Fuel Delivery Problem
7. Spark Issue
Old Nov 24, 2017
Slumpertcivic's Avatar
Could easily be a bad starter relay or starter solenoid.
Get familiar with how to manaully engage the starter via jumper wire or the correctly placed screwdriver described above so you have a chance the next time it decides to just sit there.
Starter in our car is wonderfully simple to swap, starter relay under the steering wheel is even easier.. No real easy way to figure which one got stuck if they are working now.
Old Nov 24, 2017
mikey1's Avatar
Guys,
This thread is over 11 years old
Old Nov 27, 2017
Just think of all those 50yr old barn finds, they prolly got parked originally for a simple fix.....
JetsterDajet
Aug 15, 2015 08:07 AM
jnissen
Aug 9, 2015 05:34 PM
Hqly2001
Jul 25, 2015 05:32 PM
EM_WON
Jul 22, 2015 06:49 PM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
