Idle Problems no its not when its cold start.
Old Jan 10, 2006
speedracersong's Avatar
My friend's civic has a rough idle.
Doesnt matter if the car is cold or warmed up. You start it and the car just shakes. Put it in drive with the foot on the brake and the car shakes. its like a really rough idle, the tach isnt fluctuating either. the thing is when you drive you don't feel it anymore.
it has a salvage title. got creamed in the front. engine got replaced.
possibly bad motor mounts?
Old Jan 10, 2006
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
does it still shake if u rev the engine a bit in park or neutral?
oil and plugs are good?
Old Jan 10, 2006
if you put it in neutral and the car stops shaking, you have a dirty throttle body.
Old Jan 11, 2006
ok ill try that and report back!
Old Jan 11, 2006
ok it doesnt shake when you rev it in park and neutral.
Old Jan 12, 2006
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
i would say it could possibly be the front motor mount
Old Jan 18, 2006
so what is it?
motor mount or throttle body?
Old Jan 19, 2006
throttle body is much cheaper and easier to try first. but if it is a motor mount, the car would shake while driving too.
Old Jan 19, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
tbi is easy to clean. take off intake. clean, replace, be happy. i would check plugs and wires too though.
Old Jan 19, 2006
ok how do i know the wires and plugs are bad?
sorry im totally lost on this part
Old Jan 19, 2006
MajinB's Avatar
take out each plug and see if its fouled. like black or something. or if the tip is like melted down. any car manual will have pics of normal and foulded plugs. and it will tell you what causes the type of fouling.
about the wires, look inside and see if you see calcium deposits and rust anywhere.
Old Jan 21, 2006
mradam85's Avatar
civics dont have plug wires! coil-on-plug
Old Jan 21, 2006
MajinB's Avatar
yes they do. the previous gens do. he didn't mention what gen it was...
sharp66
31
Jun 12, 2022 08:45 AM
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
Allecr3
May 22, 2015 01:24 PM
crowtoo
May 11, 2015 06:50 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
