Electric clicking from ignition
Old Dec 16, 2005
Wizkid's Avatar
Wizkid is an unknown quantity at this point
So I go to start my car this morning, and this clicking noise starts right before the starter kicks. This car is 9 months old, so I'm really hoping that its nothing serious. Anyone else thinks it sounds like the ignition having issues?
Old Dec 16, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
There are several relays that click when you turn the key. The fuel pump relay will click on, and back off when the pump is up to pressure. The ignition relay will also click. You may not have paid attention before. Well, it may be something else, but these are the normal clicks. Maybe you can describe it better? But pay attention to the normal relay clicks when you turn the key to ON and see if that's what you heard.
Old Dec 17, 2005
streetglower's Avatar
to me it sounds like a dead battery. the usually clue is when you try and start the car and it just has a rapid clicking.
But did the car start? If it did, then it was probably as tinman described.
Old Dec 17, 2005
Wizkid's Avatar
its not like the ignition normally does, and yes the car does start. It happens right before the starter kicks in, and it sounds like a mix between an electric buzz and clicking. Its definitely not coming from the engine bay, its coming from under the steering column. The funny this is that it only happens every once in a while, and it didn't do it at all today.
Old Dec 18, 2005
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
did your gauges flash? i think on the newer civics, 03+ the gauges flash too when you hear the clicks to warn you of a battery problem.
Old Dec 18, 2005
dead battery yay! get optima yellowtop, throw stock in trash (um i mean recycle place).
Old Apr 20, 2006
savedadogs's Avatar
savedadogs is an unknown quantity at this point
I had the same electric clicking a few months ago, it disappeared after 2 weeks. Strange.
Old Apr 20, 2006
PiinkSox's Avatar
PiinkSox will become famous soon enough
I have the same problem but it happens every once in a while
Old Apr 22, 2006
tinman's Avatar
Stick or Auto? If it's an auto, that's probably the key-lock. Keeps you from removing the key unless the transmission is in neutral or park.
Old Apr 22, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
same thing happens when mine is at park. i can hit the button on the shifter to pull it back (auto) but it would make a clicking sound......cheap honda, go figure
Uan
Aug 23, 2015 03:03 AM
liamfry91
Aug 9, 2015 07:54 AM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
cukaracha
Jul 17, 2015 05:48 PM
Jul 12, 2015 11:54 AM
