My Back Wheel Locked Up
Old Dec 4, 2005
teamPR0's Avatar
Won By One
teamPR0 is an unknown quantity at this point
Ok so i live in calgary right, and the weather is like really cold and before i came home from lunch i took my car to the do it yourself carwash. Well i tried to use the car at nite and well the back left wheel is locked up and i couldnt drive anywhere. could it be because my brakes are frozen or is it something else??? any help on this matter would be great. I already tried driving it on dry pavement and the tire just skids.
thanks
Old Dec 4, 2005
tacheon's Avatar
tacheon is on a distinguished road
Sounds like the parking brake cable is hung up on one side. You'll have to jack it up to see if that is the case.
Old Dec 4, 2005
Jrfish007's Avatar
Parking cable.... Did you use the parking brake when the car was being washed?
Old Dec 5, 2005
AlienX's Avatar
AlienX will become famous soon enough
ouch that sucks, i had my wheels brozen to the ground once, and front brakes frozen causing me not to be able to stop.. but try to bring your car into a warm area above 0 so you can get stuff to defrost.
Old Dec 5, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Little late, but probably got water into the rear drum and it froze the shoe to the drum. You should be able to break it loose by repeatedly stepping on the brakes hard. For next time. It may also have been the cable, in which case you break IT loose by pulling on the E-brake a few times.
In Berlin, where I came from, it's all routine every winter.
Old Dec 6, 2005
teamPR0's Avatar
Won By One
well i got it. i was driving on some dry pavement in reverse at like 20-30 and then ripped up the ebrake. it sounded like a gunshot
Old Dec 6, 2005
drew22mader's Avatar
There is gl@ss in my @SS...
lol! I can only imagine what that was like, or what the faces on people looked like when you were doing that. Its good that you got it fixed.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
jakeconnor
May 5, 2015 07:30 AM
MamaBear2015
May 3, 2015 02:17 PM
cperez53
Apr 16, 2015 09:31 PM
ademarco6
Exterior
Nov 15, 2001 09:36 PM
