Alt light question
Old Oct 23, 2005
Stubby350's Avatar
Stubby350 is an unknown quantity at this point
Alt light question
I have an alternator light that just came on and stays on unless you rev the motor to about 4000 rpm's. If you keep it above 2000 rpm's it stays out. Is this just a bad alternator or is this some other problem? The car has about 69000 miles on it.
Any help is appreciated.
Stubby
Old Oct 23, 2005
streetglower's Avatar
more then likely your alternator is failing. Take your car over to autozone and have them do an alternator output test for you for free. This will tell you weather or not your alternator is doing its job. Also check all of your connections at the alternator.
Now when the light comes on, does the car end up dieing or stalling after several minutes?
Old Oct 23, 2005
Stubby350's Avatar
No, it keeps running fine and the lights do not dim either.
Old Oct 23, 2005
I would go get the charging system checked first, and if that checks out fine, according to the manaul you may have a problem with the multiplex control unit as it controls the indicator lights. Also have the battery tested.
Old Oct 23, 2005
Stubby350's Avatar
Ok. Thanks for the information.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
klam
Nov 16, 2001 03:36 PM
