no clutch pedal
Old Aug 21, 2005
prototype's Avatar
x-factor
no clutch pedal
heres my problem, i push the clutch to the floor and its really loose. i cant put the car in gear. i noticed that i have a leak of fluid could that be the problem? it sux bc ive had tranny problems since day 1. n e help would be great thanx
Old Aug 21, 2005
etdigitalis's Avatar
etdigitalis should not be trusted
where's it leaking from? inside the car, just on the other side of the firewall, down in front of the engine?
Old Aug 21, 2005
prototype's Avatar
x-factor
its leaking from the tube that the fluid comes from the resivoir....i had a 5speed swap and he couldnt use the stock piping, he had to fabricate one. its leaking from the connection but when i have some1 pump the clutch it doesnt leak out, maybe when im driving it only does it. weird
Old Aug 22, 2005
it could only be leaking out after it warms up... the hydraulic line between the clutch master and slave cylinders weaves all around the engine, so it tends to catch some of that ambient heat.
as long as you don't let it leak to the point where air can get in the line, you should be alright... but it sounds like you already did and will probably need to bleed it after you fix that leak.
Old Aug 22, 2005
2K1Civic17"Gabe's Avatar
yeah, thats the prob. You need the pressure in the line, to keep pressure on the pedal. A leak will be the cause of that. Get it fixed, and flush the line out (a pump works best, I couldnt pump the pedal enough to get any pressure at all, for about 3 days, lol). Once you flush it out, you should have more pressure on there and be good to go!
Peace
Scout1
Oct 5, 2015 01:33 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
Klame9420
Sep 7, 2015 10:03 PM
violentpanda
Sep 7, 2015 11:49 AM
tommycanada
Sep 5, 2015 04:59 PM
