Shifting to D4, slight jerk.
Old Jan 28, 2002
01LX's Avatar
01LX is an unknown quantity at this point
Does anybody else have this same feeling? It goes like this. From Park, I shift to D4, it engages immediately, then soon after, it engages a second time, causing a slight jerk forward. I feel it is double engaging.
Old Jan 28, 2002
Whatagolfer01's Avatar
Whatagolfer01 is an unknown quantity at this point
If your motor is cold it will rev higher causing it to slap into gear. When you first start it in the morning just give it a minute to warm up. It will save you in the long run.
Old Jan 29, 2002
01LX's Avatar
Nope, not happening only in morning, happening anywhere and everywhere.
Old Jan 29, 2002
RexWatson's Avatar
RexWatson is an unknown quantity at this point
you have D4?
Old Jan 31, 2002
01LX's Avatar
D, D4, same difference.
Old Jan 31, 2002
SoFlaCivic's Avatar
SoFlaCivic is an unknown quantity at this point
I think it's the torque converter "catching up" to the engine.
Theory:
1. Engage D4
2. Get that engaging feeling.
3. Those fluids start pumping and spinning around in the torque converter.
4. Torque converter is fully pumped up and takes up whatever slack was present.
5. Get that engaging feeling again.
These cars may have a "loose" converter. This help to get it going off the line with so little
torque. This may also explain the tendency of the car to roll backwards on slight inclines.
My car does this. Don't worry about it, it's normal.
Old Jan 31, 2002
01LX's Avatar
Yeah! You make sense. My car does have a very low hill tolerance, and tends to roll back on a slight incline. Can any adjustments be made to lessen this feeling? How about a warranty fix?
Donahue
Sep 8, 2015 09:00 AM
dantheman42
Sep 4, 2015 01:10 PM
LogicWavelength
Feb 9, 2005 06:00 PM
S2000man01
Sep 12, 2002 12:05 PM
