And the problems just keep coming...
Old Jul 6, 2005
ReD2k1's Avatar
ReD2k1 is an unknown quantity at this point
aright so ive had this problem for sometime, at first it was my idle going out of control , but the problem was TPS and i replaced that and it idles fine now..now i have this problem that at any given point whether the car has just been turned on or has been running for a while, the car seems like it is going to stall but then it recovers itself, this happens a lot too when the a/c is on, also when im on the throttle sometimes it struggles but then corrects itself and then you feel it actually accelerate. im ordering the O2 simulators(LX with Kamikaze header) but as i looked through the forums it seems that its not the O2 sensors arent really the problem, any help i would appreciate it
Old Jul 6, 2005
ManUtd0018's Avatar
ManUtd0018 is an unknown quantity at this point
maybe your fuel pump has gone bad...
Old Jul 6, 2005
ReD2k1's Avatar
anyone else replaced their fuel pump and if so which brand did u get it and where?
Old Jul 24, 2005
streetglower's Avatar
I just had mine replaced because it failed after I changed out the fuel filter. I am assuming the shop used the OEM pump, but who knows.
Old Jul 30, 2005
Have you done the TB coolant bypass? Put it back to stock if you did. It screws with the idle. If the car is stock, reset the ecu and see if that fixes the problem. Warm up car, turn off, unplug neg battery term, put back, start car and let idle for 10 mins without touching gas or using accessories, turn car off. Should be fine now.
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
