idling not constant
Old Jan 26, 2002
Parisdreams's Avatar
Parisdreams is an unknown quantity at this point
idling not constant
there is a similar post like this but i beleve mine is a bit different. the other day after stop at a stop light my car's tach went crazy. it jumped between about 700 and 1500 rpms. it would go up then drop, up then drop. the car was warm and did it every time i stop. or when i released the gas. itn has done this twice. should i try something. or take of my CAI and take it back to the dealer.
Old Jan 26, 2002
emmagatorone's Avatar
emmagatorone is an unknown quantity at this point
How old is your CAI? I mean, how long have you had it on and what model do you have?
Old Jan 28, 2002
CarbonFiberSi's Avatar
CarbonFiberSi is an unknown quantity at this point
Did you reset your ECU after you installed the intake? If not this is how you do it. Make sure your car is warm (normal operating
temperature) and then turn it off. Disconnect the negative terminal from your battery for 10 min. Reattach it and start your car.
DON"T TOUCH ANYTHING! Just let it idle for another 10 min. and it should take care of the problem. If that doesn't work try taking
the fuse out to the ECU and do the same process.
Old Jan 29, 2002
Russps's Avatar
Russps is an unknown quantity at this point
This problem started happening to me recently, and I have the stock intake! Its really starting to **** me off. I need an oil change anyway, so I'll go complain to honda, again.
Old Feb 7, 2002
TeamStylesRacing's Avatar
TeamStylesRacing is an unknown quantity at this point
My car idles really low when the car is warm, it even stalled at a light ( i have an automatic ). how do i restart the ecu?
Old Feb 7, 2002
Rebew1's Avatar
Rebew1 is an unknown quantity at this point
Check to see if all of the vacuum lines are hooked up or if the have cracks in them. I know that there isn't a whole lot of them but it could be it. If you can't see any signs of damage, pick up some starting fluid and spray around the lines. If the engine revs higher you have a leak. Also in my 89' Integra I had that problem. Actually it was the altenator. Wasn't putting out enough Voltage and would cause the same problem you are talking about. If none of this works definetely take it to your dealer.
Rlss
24
Feb 26, 2016 09:42 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
msaeger
Sep 2, 2015 08:47 AM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
