Engine Stalling
Old May 12, 2005
nateschisler's Avatar
nateschisler is an unknown quantity at this point
Engine Stalling
2001 Civic EX Coupe, VTEC, 5-spd
Right after startup, I coast in 3rd gear down the relatively short hill my house sits on. I get to the bottom, hit the gas, and nothing...enging keeps running, but slooowly spools down as if I'm not touching the pedal...then...WHAMO! Gas hits, car lurches forward. Also happens if driving very slowly through an alley, or driveway or something.
Kinda makes me nervous...don't wanna blow clutch/engine when the gas kicks in real hard. Suggestions???
Old May 12, 2005
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
IS that the only time it happens? 3rd gear? going downhills? right after starup? let me know, i can help.
Old May 17, 2005
More specifically, it's more likely to happen in cold weather...but still present and "rough running" if right after startup. It happens as a result of "engine braking" and usually after startup when everything is "cold". It's not a downhill-only thing, it's happened when I've let up off the gas and didn't take it out of gear to slow down.
Old May 17, 2005
clrumivier4life's Avatar
clrumivier4life is an unknown quantity at this point
I don't know much, but my guess would be something do you with your fuel system...maybe? No...probably not...
Old May 17, 2005
Al Gore FTW's Avatar
jdmtytedoridori
my car is usually pretty hard to drive when everything is cold. it jerks like mad.
mikemc422
Aug 9, 2018 05:41 PM
docmartin14
Jul 30, 2015 11:26 AM
ywgflyer
May 15, 2015 05:05 PM
crowtoo
May 11, 2015 06:50 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
