Tire wearing issue?
Old Apr 2, 2005
streetglower's Avatar
Tire wearing issue?
I was just wondering is it possible for a tire to wear differently on one side of the tire from the other if the alignment specs are all within specs?
I ask because my passenger side tire has about 2/32nd of tread on the outside, but on the inside it has about 7/32 of tread. It looks like I have negative camber or toe out, but all my specs are fine.
I am not sure what it is, I am thinking of a worn out suspension part, but not sure. I dont think it is a balance issue cause there really isnt cupping on the tires. Any help would be appreaciated.
Old Apr 2, 2005
Zzyzx's Avatar
Autocross Junky
check your tire psi... If your tires are over or under filled that can lead to tire wear on the shoulders or in the center...
Old Apr 2, 2005
tire PSI is something I check daily and it is all fine.
Old Apr 3, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
Do you drive on an oval track?
Old Apr 3, 2005
tfnaaf's Avatar
BLDNPSI Mod
First question is do you rotate your tires every 3-5000 miles? On ALL (street driven)cars the right front tire will wear the most. Reason being is when you make right hand turns usually its smaller arc and you are going slower as in turning into a parking lot on the right. But when you say make a left turn at the corner light it usually is a faster larger arc allowing more weight transfer onto the right frt tire. Hence why the right frt tire will always wear more then any other tire assuming proper alignment, rotation etc...........
Best way to battle tire wear on right frt is proper inflation, alignment, and rotations
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bo_red
Apr 23, 2015 10:09 PM
supercivic01
South
Nov 30, 2001 11:27 AM
technosilver
Nov 14, 2001 10:58 AM
