car wont start!
Old Jan 26, 2005
thom's Avatar
/////ALPINE
car wont start!
when i try to start up my car
with ill not start
when i try to turn it on, it makes a click noise.
battery is ok.
weather is always like good 60-90 degrees.
can i be the spark plug???
Old Jan 26, 2005
check plugs, check immobilizer key, check fuel, battery, starter. Click usually means dead battery.
Old Jan 28, 2005
skillwill's Avatar
skillwill has a little shameless behaviour in the past
yup mine died in this snow storm running errons to the store
low battery
Old Jan 28, 2005
streetglower's Avatar
it is probably the battery.
Old Jan 28, 2005
mr_fobster's Avatar
if the battery dies, can you jumpstart it? i heard from a honda tech, that in the newer gen vehicles, that it is bad for the car to jumpstart it. iono if this is true or not. well if it is, then could you just get the batt and recharge it at like a local pep boys or autozone?
Old Jan 28, 2005
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
either or.. i dont think jumpstarting is exactly "good" for any car.. you can always just disconnect the batter and jump it that way then hook it back up to try it..
also make sure yer ac/heat fan is off that lil sucker draws a "lot" of power which can make cold starts even harder
Old Jan 28, 2005
jumpstarting should always be a last resort. Battery replacement is supposed to be what you do when the car wont start, when it is a battery issue. jumpstarting can have effects on the computers in the car. It can send unwanted voltages that can harm them.
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
