Should I be worried....
Old Jan 25, 2005
skratch_munkey's Avatar
skratch_munkey is an unknown quantity at this point
I have an 05' 2 door civic vp. i've only had it for 3 months. well lately my car has had trouble starting. well i really wouldn't say trouble, it just takes a couple of seconds longer to start, then when i first got it. so, should I worry about this or just ignore it.
Old Jan 25, 2005
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
Take it down to the dealer. Your warranty should cover it.
Old Jan 25, 2005
MishBallzEM2's Avatar
I'm The Ballz Of 7th Gen
MishBallzEM2 is an unknown quantity at this point
Warranty!!!!!!!!
Where do you live? If its cold where you live it could be from that...I know mine takes like 2 extra cranks before it turns over in the cold.
Old Jan 25, 2005
Jrfish007's Avatar
The other day it was about 5F out when I tried to start my car, it turned over for about 2 second before it started. Today it's about 30F and it started fine, maybe it's just the cold.
Old Jan 25, 2005
wrussi's Avatar
wrussi is an unknown quantity at this point
my sister has an04 lx and it did the same thing in the first 2k miles after that it started to work fine she has like 5k on hers right now and everytime it starts out fine
i would say wait a little more untill u put more miles on your car then if if keeps happening take it to the dealer to get it cheked out
btw: i live in florida so i dont think is the cold weather my best guess is that the starter is just "too new"
Old Jan 25, 2005
PunkingCivic's Avatar
I need TP for my bunghole
yeah, If you live in a cold/snowy area you might need a better battery. One with lot of cold cranking amps.
Old Jan 25, 2005
I FuSe I's Avatar
I FuSe I has a little shameless behaviour in the past
It says in your manual that ignition may take longer then other cars, it's because of the ULEV.
Old Jan 25, 2005
ULEV!!!!!!!!
Old Jan 25, 2005
Profoxcg's Avatar
Profoxcg is an unknown quantity at this point
that is what the dealer told me also 2 yrs ago... my car start fine for the most part, but sometimes it hessitates some, in which case i just give it some gas.
Old Jan 25, 2005
I live in Guam. its usually hot here. but recently its been cold. we're getting some cold winds from the north east of us ( japan). I guess i'll sit on it for a while. but thanx for the info.
Oh does any body here know how to remove gum off without scratching the paint. some a-hole threw his gum out while I was behind him. didn't think much of it. until the next morning walk out and thought someone keyed my car. it stretches from the front to the driver side door.
Old Jan 25, 2005
deciuss's Avatar
Boosted Auto
cold weather = the suck for starting cars.
Old Jan 25, 2005
zachgeyer's Avatar
dealer
Old Jan 26, 2005
teamPR0's Avatar
Won By One
teamPR0 is an unknown quantity at this point
use some gasoline to remove the gum with a soft terry cloth
Old Jan 26, 2005
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
desler on the starter, try to remove the gum with your fingernail. Gas might work, but it'll probably screw up the paint. you may try wd40, then afterwards wash the car really good.
Old Jan 26, 2005
Thanx for the info. I'll try it out and let you guys know how it went.
