wheel stud removal??????????
Old Jan 15, 2005
Bmkarr's Avatar
Bmkarr is an unknown quantity at this point
exactly what it says....(wheel stud removal)help, hurry
Old Jan 16, 2005
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
i think any muffler shop or brake shop would do it. I dont know how much they charge but it shouldnt be much.
Old Jan 16, 2005
streetglower's Avatar
Is it the front or rear? If it is the rear, just take off your brake drum and knock the stud through the back and put a new one in using a few washers and another wheel lug nut and tighten the lug nut untill the stud pops through.
Now if it is the front you need to go to a shop because you have to seperate the wheel hub from the knuckle and dust shield to remove the stud.
Old Jan 16, 2005
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
yes and dont let Tire Kingdom touch the **** they will **** it up...but yes the hub and bearing need to be pressed out
Old Jan 17, 2005
Bmkarr's Avatar
ok well i took it to a muffler/brake sjop today and they did it but like half way thru the process they found a slight problem, the nut on the end of my axle(hub nut) happen to stripped which still to this very minute blows my mind but it all ended up costing my a$$ a hundred bucks, but thanks for your help guys.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
elitezdc5
May 26, 2015 05:46 PM
bsmiley
Apr 27, 2015 01:27 PM
02EXCoupeGuy
Dec 19, 2001 09:47 PM
nymbus2k
Nov 11, 2001 08:53 PM
