First Oil Change
Old Nov 25, 2004
rescuer87's Avatar
rescuer87 is an unknown quantity at this point
First Oil Change
I have a 2004 Civic Ex that will be 6 months old on December 5th. Should I change the oil for the first time even though I only have 2100 miles on the car or should I wait.
Old Nov 25, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
yea change it why not....its only 15 dollars. wow u drive only 5k/year.....is ur work next door to you and ur school right across the street or something?
Old Nov 25, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
i miss living 3 miles away from my work..
Old Nov 25, 2004
takumi's Avatar
takumi is on a distinguished road
Honda says you should change it at 5k the first time. When I hit 3K, I tried to make an apppointment for an oil change but they said to wait until 5k. Now it's at 3.5K and I've had the car for 8 months already.
Old Nov 25, 2004
diy it!
Old Nov 25, 2004
vtecpimp's Avatar
vtecpimp is an unknown quantity at this point
Do it at three k, I am sure that you have already driven it pretty hard a few times. The reason that you are supposed to wait is so your motor can properly break in. Your piston rings provide needed resistence in your motor, if you change your oil too soon, you mess up your engines chance for doing this. Waiting too long between oil changes ( synthetic or not, I know from past expierience ) causes sludging in your motor which makes too much resistence. Change your oil every 3k, then at 9k, swithch to a proper weight full synthetic, you will notice a slight difference in how smooth you engine sounds(plus it protectes better at high rpms), use a Honda filter with it, put 10w40 full synthetic in your manual transfer case and see how smooth your gear changes and shifter action will become.
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
BootyDo
May 7, 2015 04:46 PM
SoNiCcIvIc
Mar 11, 2002 03:37 PM
AnotherDopeStyle
Jan 5, 2002 03:10 PM
