Slight Grind in Second Gear
Old Sep 11, 2004
2004CivicHBSi's Avatar
USMC - Semper Fi
2004CivicHBSi is on a distinguished road
Hey. For some god forsaken reason. Every honda I had, had a grinding problem going into second. Now it could just be me.. but I dont know. I got a 04 Si..... now sometimes it has a small grind going into second when I race... can anyone tell me why it's doing that? Clutch still not down all the way? THanks
Old Sep 11, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
It's the tranny, and the way it's designed.
While some here don't agree with this, I fixed my problem by squeezing a small tube of MOLY LUBE into the gearbox. It takes a couple of hundred miles, but my transmission shifts smooth as butter now. So does my brother's 6speed accord, and so did all my previous honda's.
Old Sep 11, 2004
phuviano's Avatar
Slowest 7thgen in the GTA
My 04 does the same thing. It grinds a little in 2nd. I have also felt a slight grind in 3rd. My car doesn't always grind in 2nd though. Its not the clutch, cause I've tested it. I make sure I push the clutch all the way down, and it still grinds sometime.
When you say grind, you mean you can feel it right?? You can't hear you tranny grinding, right??
I have the grinding feeling in my tranny, but not the grinding sound.
I don't have an si, but I have an ex. I believe this is a common issue.
Old Sep 11, 2004
2K1Civic17"Gabe's Avatar
My car grinds in second once in a while. I have a LX. It doesnt happen very often, but only in second. So I am pretty sure it isnt me (my foot is all the way down).
Old Sep 12, 2004
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
same here, grinds sometimes in second, it feels like its in gear but for some reason it isnt
Old Sep 12, 2004
JCiv03's Avatar
Same here, it seems to be a common problem that has been around for a while. Although no one has a definate answer for this... But it only happens once in a while.
Old Sep 12, 2004
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
My car did this for a while... However, and this might just be a coincidence, but ever since I changed to Redline MTL, I don't believe it's ground 2nd. Like I said, could just be a coincidence, but over the last 10K or so I don't believe it's done it.
Old Sep 12, 2004
tinman's Avatar
There is a petition that the RSX owners have been signing about the same problem.
My "GUESS" is that the stock honda fluid is a little too thin, or maybe a little too thick.
That would explain why a modifier like Moly (in my case) or a different oil altogether like redline seems to fix this problem.
Yeah, Honda engineers really knew what they were doing. Riiiiight.
I'm very happy with how my car shifts. Next fluid change I'll give redline a try and see how it differs from my moly treatment.
VTEC01EX, a lot of people have the same result with redline MTL. No coincidence.
Old Sep 13, 2004
phuviano's Avatar
Where do you add the moly lube to?? I mean where do u put in??? You got any pics?? thanks. I wanna try out your idea, I just dont' know where I add the moly lube stuff.
SidCivic
Sep 12, 2015 05:28 PM
WaryDriver
Aug 16, 2015 11:22 AM
JetsterDajet
Aug 15, 2015 08:07 AM
Bonnabell
Aug 14, 2015 04:15 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
