engine feel shutting off
Old Aug 1, 2004
HELP_ME's Avatar
HELP_ME is an unknown quantity at this point
Unhappy engine feel shutting off
omg... ok... here's the problem..
I have an OBX header in my car and a HKS rear section on my car, and recently I installed the O2 sim in it, then took it for an oil change. Next thing I noticed that when I start the engine idle... the RPM is dropping constantly and when I'm running with my car at around maybe.. 30 mph. RPM cant go up any higher than 3000 and sometimes it comes back normal... and sometimes I feel like engine is shutting off on me when idle... I feel like I cant push over 3000 RPM... (the engine check light is not on, since O2 sim)
my car is pretty new... only has 24000 miles on it... I DONT know what to do... help me........
Old Aug 2, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
your ecu needs to calibrate, take the ecu fuse out and put it back on after a couple of mins.... that should fix it... and also clean your air filter
Old Aug 2, 2004
HELP_ME's Avatar
Can I reset my ECU by reconnecting battery... that's what I've been hearing...
Thanks a lot...>_<
Old Aug 3, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^^ yes. disconnect the negative terminal for a few min ... turn it back on ... wait for another few min with engine idling (don't press the gas), turn it off, turn it on again
Old Aug 3, 2004
chrisleecool's Avatar
^^^ yea I think so .
what's up with ur car lately richard?
I saw ur car at AMC16 last night
what did you see? I saw the whitecastle ****..It was pretty funny hehe
Old Aug 3, 2004
HELP_ME's Avatar
alright... I tried reset ECU by reconnecting battery... and the problem still remains...
Where can I find the ECU fuses? HOW...? >_<
Old Aug 3, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
spark plugs?
Old Aug 3, 2004
PunkingCivic's Avatar
I need TP for my bunghole
above the gas pedal I think
Old Aug 3, 2004
HELP_ME's Avatar
anyone knows that which wire im suppose to unplug?
so many wires under it...
Old Aug 3, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
ecu fuses are in the fuse box. the big back one and the other one pretty big one ... it says on the fuse box cover
Old Aug 3, 2004
HELP_ME's Avatar
i removed the fuse box cover... so now im looking for the big black wire now? and unplug it?
Old Aug 3, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
wire? ... it's fuse, not a wire. Look at the fuse box cover.
fyi, disconnecting your negative terminal on your battery works fine to reset your ecu. I would check your spark plugs as they may be busted
Old Aug 3, 2004
HELP_ME's Avatar
hmm... interesting point... well i checked those as well... but I cant really tell if they are still ok... if they gone bad... what kind of spark plugs I should get? The Denso Iridium?
Old Aug 3, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
well, you want to make sure they're tightened enough ... I believe it's 18 foot pounds of torque. Make sure they're gapped all the same. Goto www.densoiridium.com ... their website is very informative about checking plug condition
Old Aug 3, 2004
y.0. KiLLa's Avatar
Powered by Honda
get rid of ur obx headers..they are cheap...perhaps thats the problem..
Old Aug 5, 2004
Just take off the header. The ecu is very picky about calculating the correct air/fuel ratio. The O2 sim is probably messing it up.
Old Aug 17, 2004
big_daddy_b_99's Avatar
big_daddy_b_99 is an unknown quantity at this point
ever find out what was causing the idle problem cause i'm havin the same problem but i don't have a header on mine right now.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Ninetyatecivic
May 9, 2015 07:48 PM
smmahan
Apr 15, 2015 08:17 PM
