prob with evo2 exhaust
Old Jul 27, 2004
ncampbell2002's Avatar
ncampbell2002 is an unknown quantity at this point
Hey guys, I'm having a major problem with my new exhaust and I wondered if anyone else has experienced the same problem and what they did to fix it. I have an 03 Ex coupe and after I had the exhaust installed, it will rattle and vibrate violently right up near the cat. I know its around there cauze you can feel it come up through the floorboard right underneath the shifter. I jacked up the car and found everything to be very solid and tight. Nothing looked out of the ordinary. There was nothing that was touching or anything that would cauze a vibration. Could someone please help?!? It feels like my car is going to vibrate right apart if this continues. It feels even worse if you are sitting in the passenger seat. This will happen under acceleration, cruising and idle. It is really embarrassing when you have a decent looking car sitting at a light and you have an exhaust clanking underneath the car. Thanks for any advice.
Old Jul 28, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I have the same problem, it's most likely hitting the heat shield ... either bend the heat shield or take it all off and put it completely back on (hopefully shifting it will fix the problem)
Old Jul 28, 2004
Armin's Avatar
Armin is an unknown quantity at this point
it could be ur catalyc converter-gone bad.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
jtcavey
Sep 30, 2015 02:18 PM
juicetayne
Sep 30, 2015 11:02 AM
raymondxcho
Sep 29, 2015 09:00 PM
