humming noise
Old Jul 23, 2004
KidCivic's Avatar
KidCivic is an unknown quantity at this point
humming noise
My girlfriends car is starting to sound like it has a bad wheel bearing. It sounds sometimes like its in the front and other time in the back. I honestly dont think that it is because it doesnt change in sound when you weave back and forth. Now in my 6 years as a mechanic it should change sound if you turn. The only other thing i can think of is maybe there is something underneath that is catching the air and making a noise or the exhaust but it doesnt respond to rpm. Any ideas on where to start I would be grateful.
Old Jul 23, 2004
streetglower's Avatar
usually bad wheel bearing will make a thumping sound noise when you start to break and when driving, not a humming noise. As far as what it is, we need more details. It could be anything.
Old Jul 23, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
jack the car up and see if you can move the tire around
Old Jul 25, 2004
KidCivic's Avatar
Im going to buy a floor jack and put the tires in the air and spin each one and hold the spring to see if that is what it is. Wheel bearing do not thump when you hit the brakes. They hum like a **** and they get louder when you turn left or right dependging upon which one is bad. I also noticed that thier is an exhaust rattle. So i also have to check that because it does also sound like a couple of sounds that are making noises that might be put together to make the one i am chasing.
Old Aug 23, 2004
Iaafm's Avatar
Iaafm is an unknown quantity at this point
Did you find out what it was? My car has a slight humming sound as well.
Old Aug 29, 2004
KidCivic's Avatar
I have checked and its probably the road surface up here. We live in eastern mass and she took a trip to RI yesterday and it was no where near as loud. My Regal Gs is even loud on the roads up here and i know that thier is nothing at all wrong with that car. The tires are a little chopped and that may be what is making the noise worse. It has been getting better as she drives it also so i think most of the noise was in the tires.
Old Aug 29, 2004
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
Do you have stock Firestones? Mine hum like crazy on some roads to the point where I have to turn the radio off to see if something is wrong. Then they are quiet on other roads.
Old Aug 30, 2004
KidCivic's Avatar
No i wouldnt let her buy firestones again. I made her get Micheln Pilots. Im not sure but i think its the roads up here because my Buick never made noise until i moved up here. I might be the wheel bearing in its beging stages so im definitly going to keep an eye on it.
Old Aug 30, 2004
How about you just take it to a shop and have them check your car out.
Old Mar 8, 2005
KidCivic's Avatar
I am the shop for this and my car cause i am a tech myself. I also have never heard this sound in my 8 years in garages. Her brothers car is now making the same noise so i am checking it out on saturday and if i see that its a bearing then thats what i will try with her car.
Old Mar 15, 2005
zero's Avatar
zero is an unknown quantity at this point
Damn! Any updates?? My girlfriend's car is making the same sound. I thought it was the stock firestones. Change them out to another set and still noisey like heck. It sounds like it coming from the front left side only.
Old Mar 16, 2005
clarkscivic's Avatar
clarkscivic is an unknown quantity at this point
I had a humming noise in my car too. I fixed it by kicking the guy out of my trunk. Damn hobo
Old Jun 10, 2005
zero's Avatar
UPDATE!! Took the car in and it was the damn wheel bearing. Changed it out and no more sounds.
nirvanaguy
25
Oct 26, 2017 07:26 PM
JetsterDajet
52
May 8, 2016 12:11 AM
fvckbg
Sep 8, 2015 09:55 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
tommycanada
Sep 5, 2015 04:59 PM
