what makes car run bad?
I don't have any leaks. The head install went perfectly, and we used new gaskets for everything. Better than new. Still that rough idle is there. I'm almost betting it's a valve adjustment or something simple.
Would higher compression cause any problems?
I have an idea....disconnect the battery (overnight)....hook it back up and turn on the car but DO NOT TOUCH THE GAS!!! Let it idle for 15 min WITHOUT TOUCHING THE GAS!!! After your 15 mins are up go driving but drive it hard.....bring it up to 5-6 g's when you shift. Do this for about 15 mins and you will be all set to go baby! 1 peppy Honda Civic for long time!! Those darn ECU's need constant training....they are so forgetful!.
I already tried to reset it, and it didn't work. The head has larger exhaust ports, polished, with racing valves. It is also milled 1mm under stock. Now when I turn on the AC and rpms go up a little, the shaking at idle disappears.
Oh okay. The guy said the one he used was like $500 or something. But he just ran a test and it said there's no problem. Maybe I should see if he can get the sensor input.
On a side note, what happens if the car is running lean? I know there's a cel for it, but not sure when it actually turns on. I need to find a way to measure air/fuel ratio. Gauges don't really work well, and a dyno is far away.
The ambient tempature has a big effect on power. Along with humitdity and many other factors. Your probably going to find that on cooler days the car runs like a bear and hot humid days it runs poorly. Beyond those simple things thier is a possibility of a lazy o2 sensor that could do that or even an air intake temp sensor.
CarStuff
Dec 6, 2020 12:52 PM
beneditti
Jan 15, 2016 12:31 PM
dragonsblood
Apr 27, 2015 12:28 PM
