Hood will not close
Hood will not close
for some reason the hood on my 04 will not close. i am not sure what the problem is but the latch may be broken. my other car is an old 3 series BMW and the philosophy behind closing the hood on that car is a world apart.
can anyone point me in the right direction?
The philosophy behind closing the hood? Isn't the philosophy behind closing the hood on any car to prevent access to the engine bay and restore driver visibility?
If you don't want the dealer to check it out, kneel down and look at the latch as the hood hits it. That'll let you know if the latch is busted or not.
you might have to adjust your hood latch for it to close properly. just do what VTEC01EX said about looking at the hood latch when it closes. you might have to loosen the bolts that hold the latch and move it up a bit for it to catch all the way.
< My future wife.
Or... put that gray plastic reservoir (with the red cap) just behind your driver's side light back into its bracket. I don't know how many times I had to move that aside to get access to my headlight bulbs, and then tried to slam my hood closed before putting it back on its bracket.
I have 2004 civic sedan made in Turkey and I got same problem, I had to slam the hood until it closed :P
so what we do now? If we have too much money contunie to slam, if we not we goto the dealer
no realy ..what was the answer?
no realy ..what was the answer? Thread
rnaodm
Sep 21, 2015 12:42 PM
