Problem with fuel gauge?
Old May 22, 2004
Okay, here's the situation. I've been driving around for 75 miles since last fillup, and the needle has stayed at or above the full mark the whole time! What's going on? I've never had it stay above full for more than 30 miles.
I had a fuel sender replaced before, but that happened when the fuel gauge would read empty even though there was still 4-5 gallons in the tank.
So I'm not sure what the problem is. I think the actual gauge is working, since it goes up and down when the car turns on and off. It's just staying on full for a long time now. Thanks for any help.
Old May 26, 2004
gzd04civic's Avatar
gzd04civic is an unknown quantity at this point
i seem to be having some issues with my fuel gauge also but the honda dealership decided after looking at it that nothing is wrong without checkin out the rest of my fuel system
Old Jun 20, 2004
Samari's Avatar
my car is now starting to do taht. it reads empty but i know i got like 70 miles or so left. also it jumps up and down. how do i go about get the sender replaced or fixed?
Old Jun 20, 2004
Well I think mine fixed itself for now. But when my sender went out, I had four gallons left when the light came on. Just take it in and tell them to fix under warranty. Make sure you warn them not to spill gas on the backseat when they do it--like they did to mine.
Old Jun 20, 2004
streetglower's Avatar
man Everyone keeps talking about warranty, bad thing about my warranty is I have a $100 deductable. It sucks.
Old Jun 20, 2004
Mistro's Avatar
Mistro is an unknown quantity at this point
Well im not to sure but i think they design cars like that for those people who like to wait till the last minute to fill up. it saves there buts many times. And about it jumping up and down it does that when your accelerating sometimes since there is more gas being sucked out and that somehow messes with it. Try accelerating at WOT and youll see what i mean. Itll sink down real fast and slowly rise back up.
Old Jun 22, 2004
tacheon's Avatar
tacheon is on a distinguished road
That's a bunch of baloney. Your fuel pump doesn't suck up fuel any more when you're accelerating compared to when you are idling. The fuel pump maintains a constant pressure to your injectors. Any excess fuel that isn't taken up is returned to the tank by a fuel return line. The fuel gauge moving while you are driving is caused by the sloshing of gas in the tank. The sender is a float connected to a rod and transducer which reads the height of the fuel in the tank. A fuel gauge which appears to "stick" or "jump" is due to flat spots or dead spots in the transducer. The only way to fix is by replacing the transducer. This involves dropping the tank. Furthermore, driving until empty is a sure way to shorten the life of your fuel pump. Fuel pumps rely on gasoline to cool and lubricate. If you have less fuel in your tank, there is less fuel surrounding the pump, therefore less cooling and shortened life.
Old Jun 22, 2004
taz757's Avatar
That'd be 100% true if we had a return line.
We have a returnless setup, so all gas will burn up in the cylinders until more is injected.
Old Jun 22, 2004
tacheon's Avatar
LOL. Yup. My bad. Was thinking about my old car. You're correct. But you still wouldn't see the fuel visibly drop on acceleration in that case.
Old Jun 22, 2004
civic_khaos's Avatar
civic_khaos is an unknown quantity at this point
i know in the buffalo, ny area, many people were experiencing problems w/ their fuel sensors as a result of bad gas.
i don't know if you guys are experiencing the same problems, but you can read the article here:
http://www.wivb.com/Global/story.asp?S=1929553
Old Jun 22, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
This is not a warranty issue yall, this is just how the civics are.
This is a very common problem that people have just learend to deal with. Our fuel gauages are incredibly inaccurate and thats why I recommend just resetting the trip odometer each time so you know how much you left on your tank...
Old Jun 22, 2004
Mistro's Avatar
lol Ok my bad then.. Just something the guys at clubcivic were saying. Never experianced it for myself so i shouldn't have mentioned it.
i stand corrected
CarStuff
Dec 6, 2020 12:52 PM
mistermenphis22
Apr 3, 2016 08:06 AM
werdnahall
May 17, 2015 11:37 AM
tylerginevan
Apr 27, 2015 12:29 PM
