Having problems with 2nd gear?? PLEASE HELP
when im in 1st gear and i go to 2nd, it feels as if its goin into 2nd, but then it just pops back to neutral..i dont understand why its doin it...it does it sometimes and sometimes it doesnt do it...it doesnt grind or anything...So i have no idea whats goin on...some1 please help
There've been people with that exact same problem.... specifically 2nd popping out. If i remember rite it's the gear's synchro's that are dammaged/bent. It might be another part (correct me if i'm wrong), but it's something you should have fixed... hopefully under your warranty
check the clutch. Cause that meens the clutch isn't catching all the way in second. You might eventually need a new one.
this has been covered many many times. it should be replaced for free at ur dealer with or without warranty. print this out and bring it to ur dealer:
PRINT THIS
PRINT THIS
Balut Eating Champ
Shifting from 2nd-3rd missed gear!!!
well mines when I shift to first and it doesn't wanna go in, I have to let go of the clutch and put it back to 1st... I just got ACT Extreme Clutch and Flywheel and it doesn't do it all the time just once in a while...
And also, when accelerating and shifting from 2nd to 3rd sometimes it misses the gear and I'm grinding it bad, this happened about 4-6times already... and it's pissing me off
Is this a related problem, or my SS needs to be changed coz I can feel it wabble a little bit when on gear...
http://www.petitiononline.com/civicsi/petition.html go here and sign
Blazz
Jun 4, 2015 01:04 AM
Marcus2thextrem
May 10, 2015 03:08 PM
McD
Apr 16, 2015 10:46 AM
Russps
Nov 8, 2001 02:00 AM
