HELP gas lever..
Old Apr 25, 2004
CarpeDiem's Avatar
CarpeDiem is an unknown quantity at this point
HELP gas lever..
Guys, That gas lever that you push down to pop open the gas tank is screwed!! i have absolutely no gas and when pushing down nuthin happens...pulling up the trunk pops open???
is there any other way to open the gas tank door....i tried jammin my key in there and that didnt help...got more scratches but didint help!!
any ideas????
Old Apr 25, 2004
ponyman's Avatar
ponyman is on a distinguished road
are you still under warranty...if so goto honda
Old Apr 25, 2004
CarpeDiem's Avatar
i'm at 64km's over warranty!!!
i tried hitting that tab with my keys and dinged it!!!
Old Apr 26, 2004
MisterTinkerTrain's Avatar
Proud Protaganistic Propagandist
MisterTinkerTrain should not be trustedMisterTinkerTrain should not be trustedMisterTinkerTrain should not be trustedMisterTinkerTrain should not be trustedMisterTinkerTrain should not be trusted
Take the trim piece with the gas pulley off and you should be able to do it manually inside the car.
All it is is a pulley system.
Old Apr 26, 2004
well cable system like the brakes on a bicycle...but I forgot to add that the parts to fix that level will run a little over 20 bucks. I had the trunk one go bad on me..
Old Apr 26, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Moving to Vehicle Issues.
Also, I think if you are only 64 KM over warranty they will still fix it...if they dont thats damn shitty of them.
Old Apr 26, 2004
nivenmk1's Avatar
nivenmk1 is an unknown quantity at this point
I'd dig around in the trunk and see if there isn't a fuel door release somewhere in there... I'd look through my owners manual, but lost it a while ago...
Other than that, take it to honda, if they should fix it, refusing warranty issues at 64km over warranty is just shitty (as Mystic pointed out above).
Old Apr 26, 2004
CarpeDiem's Avatar
I dropped it off this morning and they aint covering it under warranty..
fk them.,...i have absolutely no gas so have no choice...160 buks + tx
HIGHWAY ROBBERY!!!
i cant believe this...
I'm gonna talk to the service mgr and YELL!!
Old Apr 26, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
next time jam a plastic card such as a credit card and see if you can open the door. It seems like its a common problem for some people having their Gas door cable go loose. I had a problem with the trunk lever, but not the Gas door lever.
Old Apr 26, 2004
nivenmk1's Avatar
Good Grief!!!
$160 so you can put gas in your car is close to extortion...
Old Apr 26, 2004
pvillcivi's Avatar
pvillcivi is an unknown quantity at this point
That happened to me too. The cable housing came loose from where the lever attaches. A two dollar bottle of super glue and I was up and running. You need to remove that plastic trim peace and superglue th eblack cable housing onto the clear plastic piece onthe lever mount.
Old Apr 27, 2004
clownprince's Avatar
Ricerus Maximus
all you have to do to open the gas door is:
1. open your trunk
2. pull down the carpet on the drivers side behind the gas door.
3. find the cables that go to the door and give them a slight pull, door should open.
then you can take the time to reattach it to the lever. I have fixed this on my neighbor's 2003 Accord and my other neighbors 03 civic.
Old Apr 27, 2004
lxl_lvlartin_lx's Avatar
lxl_lvlartin_lx is an unknown quantity at this point
A few Problems i noticed with the 01' Civic Sedan..First off, the Gas release Rusted and the line snapped...went to Honda within the warrenty, and they kept changing it, i had to go back to Honda 3 more times since the first time it snapped...Second off, the trunk would open because of something loose with the trunk, trunk would fly open after driving on bumps on the road...i know this isnt a problem, but i think its rediculious...2001 Civic Automatic...has a tach...the 2001 Civic Manual..has no tach...who was smoking what when they decided to put a tach in a automatic and not in the manual version..
Old Apr 27, 2004
OniChi's Avatar
OniChi is an unknown quantity at this point
probably had a brain fart and switched the instrument panel drawings around.
Old May 25, 2004
rude_d17a1's Avatar
rude_d17a1 is an unknown quantity at this point
I have the same problem in this article. Does anyone know where a picture that shows how the mechanism works is? an/or the easiest way to get the running board plastic thing off easily?
Old May 25, 2004
zen_master's Avatar
1. open your trunk
nice, i'll remember this =)
mistahlorax13
21
Nov 18, 2015 12:47 PM
tropicola
Sep 25, 2015 07:02 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
