overheating why
Old Apr 2, 2004
vandejr93's Avatar
vandejr93 is an unknown quantity at this point
Unhappy overheating why
my car seems to be overheating and i noticed that the damn fan isnt working. it doesnt turn on to cool down the radiator . ive checked ever single fuse and relay and nada. ive about given up hope and think im just going to take it to a place where they check ac/s cause i have no warranty and the dealer wont bother looking at my car due to to many mods. what do i do?
Old Apr 2, 2004
kyle4583's Avatar
207 Mod is 10-8
kyle4583 is just really nicekyle4583 is just really nicekyle4583 is just really nicekyle4583 is just really nice
i was going to say fuses, but if you've checked them ALL then no idea...
Old Apr 2, 2004
Zzyzx's Avatar
Autocross Junky
sounds like the thermostat has gone bad.
Old Apr 2, 2004
MALBERS's Avatar
MALBERS is an unknown quantity at this point
did you pull your relay out and run a jumper wire across the power and ground terminals. this would kick your fan on. if it doesn't then you have to make sure all the connectors are tight and secure. if they are you have a short somewhere. don't forget to have your key to the on position to supply power.
Old Apr 3, 2004
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
check your coolant level.if its low it wont be able to sense the temperature.
Old Apr 3, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
This may be related to your AC problem too ... take it to a shop asap.
Old Apr 4, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
I was thinkin the same thing... if it is, make sure you get the proper thermostat to replace the busted 1. Dont get a higher temp thermostat. good luck!
Old Apr 5, 2004
03white5spd4d's Avatar
03white5spd4d is an unknown quantity at this point
i would replace the thermostat and see if that cures it. changing it is not hard, just make sure you have a few extensions, a universal joint, something to scrape of the old gasket, and get a NEW gasket ..dont reuse the old one. just follow you lower radiator hose to you thermostat housing.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
solarpunk70
Apr 12, 2016 11:43 AM
raymondxcho
Sep 29, 2015 09:00 PM
hondalx2002
18
Sep 15, 2015 10:54 PM
tooly145
Sep 5, 2015 01:05 AM
