Safety Recall ALL 2001 civic's some 2002 civic and Hatchbacks
Old Apr 1, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
As of April 5 2004 all 2001 civic and some 2002 civic's owners(depending on vin breaks) will recieve notifcations about the service bulletin 04-015 SAFETY RECALL : combination Light switch. Let me type out what honda has notified me about from work. "The low-beam terminal on the headlight wire harness can overheat and may cause the low beam headlights to fail without warning. Although the high-beam position still remains operational, an unexpected loss of low beams could result in a crash". ( American honda Motor Co inc)
The first one we did today looked pretty bad, the connector was melted and the tip of the wire was black. When you bring the car in for the recall you will be getting a new headlight combination switch along with a new connector and wire (if needed). If your cars number 16p headlight wire is discolored from heat damage we will replace it by cutting off about 150mm of the orginal wire and will connect a new wire using a splice connector. The reason why im informing you guys about this problem is because I dont want to see any one get hurt because of loss of headlights.
Here are the vehicles affected
2001 Civic : ALL
2002 civic :
2-door
From VIN 1HGEM2...2L000001 thru
1HGEM2...2L024169
4-DOOR
FROM VIN 1HGES1...2L000001 THRU
1HGES1...2L024203
FROM VIN 1HGES2...2000001 THRU
1HGES2...2L028089
FROM VIN 2HGES...2H500001 THRU
2HGES...2H530552
FROM VIN JHMES1...2S000001 THRU
JHMES1...2S004507
FROM VIN JHMES2...2S000001 THRU
JHMES2...2S002838
HATCHBACK
FROM VIN SHHEP3...2U300001 THRU
SHHEP3...2U300222
CNG
FROM VIN 1HGEN2...2L000001 THRU
1HGEN2...2L000181
2000-01 INSIGHT : ALL
Again
Notifications to civic owners will begin mailing on april 5 and contiune through the month of april. The notification letter to insight owners will be mailed later.
Hondas repair strategy
The repair is to replace the combination light switch, the RED/WHITE wire in the headlight wire harness and if needed , the 16P headlight wire harness connector. For repair , VIN and warrentry information , refer to service bulletion 04-015, safety recall : Combination Light Switch.
Jeff
Old Apr 1, 2004
flotsamm's Avatar
Thanks Jeff. I'll make sure to check my VIN.
Old Apr 1, 2004
cryption's Avatar
2003 Nissan Frontier
i have an 01 civic and i always drive with the lights on .. have been since i got the car ... no problems?
Old Apr 1, 2004
meezo's Avatar
meezo is an unknown quantity at this point
Exclamation
hi & thanx jeff 4 this information,
but what i wanna ask does this applied on the middle east models too ??
like in the arabian gulf i never heared about a recall on a car unless i go & have a bigh fight with the dealer in bahrain, then oly my problem will be fixed in not that professional way
& to add on this i had my headlights changed 8 monthes ago coz of a change in the lenss color & few months later i found that i get weak light & what was written in the report that head light wiers found lose & re-connected !!!!
Old Apr 1, 2004
abmerop18's Avatar
Jam out with your clam out.
for an 02 coupe ending in 71840, this does not effect me?
Old Apr 1, 2004
chicohonda02's Avatar
Since 2002 Baby!
i GOT MINE FIXED WITH THAT EXACT PART TODAY. I'M PRETTY HAPPY ABOUT IT
Old Apr 1, 2004
Since 2002 Baby!
OH DID I MENTION THAT IT WAS FFFFFFFFFFFFRRRRRRRRRRRRRRRREEEEEEEEEEEEEEEEEEEEE
Old Apr 3, 2004
Roosbok's Avatar
Roosbok is an unknown quantity at this point
First the struts go and now this. I thought Civic was supposed to be an exceptional car, not just a fair to middlin car. I don't know if I will be sticking with Honda after this.
Old Apr 3, 2004
BoSS's Avatar
BoSS is an unknown quantity at this point
does it matter if my warranty is over or not?
Old Apr 3, 2004
civicstyle82's Avatar
civicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to all
My warranty is up in about 700 kms so I should probably check my VIN.
Old Apr 3, 2004
Roosbok's Avatar
I think where it is a safety recall, it still has to be covered after warranty expiration. After a certain number of years I don't know if safety recalls are still done though. Older cars don't seem to get recalled, when you would expect the recalls to increase. Plus if the components are failing for safety issues that maybe other non safety issues will arise too and as everything starts to go on these cars after 3 years I think we will be stuck with the high repair costs.
Old Apr 3, 2004
MIT's Avatar
MIT
MIT is an unknown quantity at this point
damnn....my car is on listed. but i didnt receive any mail for recall! should i bring my car in and just tellin them to fix it or i do need an aponiment?
if so, can i bring my car in to any of Honda dealer or the dealer that i purchased my car?
thanks for info.
Old Apr 4, 2004
Since 2002 Baby!
thanks for info.
Just call them up and tell them you want to get your Shiznit fix on the recall. Hopefully they won't ask any question. but make sure you comlain a little about the inconvience it has been for you, that the part broke. Then they should take care of you.
Old Apr 8, 2004
runner1738's Avatar
I just noticed today on my driver side the low beam bulb went out do you think this is because of this problem, or did my bulb just burn out? ill check my vin number but it sucks this is the first time i noticed it, i have tyc projectors and the low mean were mtec h1 12v 55 w super white bulbs less then a year old if i remember correctly
Old Apr 8, 2004
AbercrombieFF's Avatar
AbercrombieFF is an unknown quantity at this point
it can definitely happen - it did to me. i never lost use of my low beams, but was replacing my OEM headlights w/projectors. When i pulled the plug from the right side bulb, i was kinda shocked. Half of the plug was melted. still workable though. glad i read this thread
Old Apr 8, 2004
runner1738's Avatar
looks like ill take it in soon and have them look at it , i would they shouldnt charge me just for looking at the part right? even if i have tyc projectors?
Old Apr 9, 2004
runner1738's Avatar
well i just took out my bulbs and there black on some spots and look kind of melted looks like im taking it in
Old Apr 10, 2004
streetglower's Avatar
I talked to honda and they said they were going to send me the recall, but never did, can I still take it to honda and have it replaced for free cause my headlights go out so often.
Old Apr 10, 2004
runner1738's Avatar
wait yours just turn out, the bulbs just odnt burn out or something?
Old Apr 13, 2004
deltaagent111's Avatar
deltaagent111 is an unknown quantity at this point
hrmmm.....i'll check my VIN tomorrow, but this is interesting, because i've now gone through FOUR sets of lightbulbs, all because the lowbeam had gone out. the last set i had in it still worked, but it wouldn't pass inspection because they said they weren't street legal lights (even though they said DOT right on them, and the package said street legal on it.....) but either way, they said i had to buy their lights (i prolly coulda gone somewhere else to get them for less, but how could i get there, they put a VOID inspection sticker on it, and i could get ticketed for driving it....grrrr) so anyway, i had to spend the 30 bucks or so on THEIR lights, then they wanted FIFTY DOLLARS!!! yes, 50 bucks to install them....i was like...umm......how about NO.....gimmie back my key and let me go put them in.....and then about 1 min later, i came back in, gave them back my key, and told them i was done, and the guy was like "already?!".....(that kinda worries me that he expected it to take a long time......<rolls eyes>....) so then i sat in the waiting room for ANOTHER hour and a half so i could wait for somone to go look at them and see that i put their lights in them. grrrrrrrrr......
Old Apr 13, 2004
CapYoda's Avatar
Escaped Convict
I got the notice so I guess I'll head in one of these days.
Old Apr 13, 2004
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
I just got my recall in the mail today..The Dealer shouldn't give me any hassle because I have Aftermarket TYC Projector headlights should they? Because the headlight assembly has nothing to do with the actual harness..
Old Apr 15, 2004
I've got TYCs also; I doubt they'll make a big deal of it since the coupler is completely independent of the acutal headlight bulb. AS far as finding out for sure if your Civic is affected, call Honda America (1-800-999-1009) & they'll run your VIN to see. If it is, they'll help you find the closest dealer to fix the shiznit & will give you their number.
Old Apr 16, 2004
elitecivicex01's Avatar
elitecivicex01 will become famous soon enoughelitecivicex01 will become famous soon enough
jus got mine in today. tomorrow (April 17th) is FREE 40-point inspection day at Holler Honda here in Orlando, FL; so ill have to schedule an ADDITIONAL appointment when i drop off the car tomorrow for the inspection. W()()t...love that free stuff. inspections are a GOOD thing to know about...hehe.
chalk another Honda owner with a recall up!
~Joey
Old Apr 17, 2004
man, I still havent recieved mine yet.
Old Apr 23, 2004
TMQ's Avatar
TMQ
TMQ is an unknown quantity at this point
Is there any TSB document (pdf file format) somewhere that we can use to show it to the dealer? otherwise the dealer will keep putting it off.
Old Apr 23, 2004
TMQ's Avatar
TMQ
Also, does any one know what the TSB number is to use to search?
Old Apr 28, 2004
nogi1's Avatar
nogi1 is an unknown quantity at this point
my car is a 01 and the connecters fine does it mater if it is a canadian or us car
Old Jun 21, 2004
I still never got the notice in the mail
Old Jun 21, 2004
skjinx's Avatar
skjinx is an unknown quantity at this point
I seem to have gotten this letter a while back, problem is, I never did take my car to the dealer yet. I'm at war with crown honda in St. Pete, FL so I'm going to another dealer in another city (clearwater). I'm scheduled for today and hopefully it isn't too bad. I also have TYC's on but they shouldn't say anything because the Honda dealers have started selling TYC accessories lately.
Hope they actually do anything though, rather than not take me seriously and dismiss me off to go.
