can't reset Maintenance Required Light
Old Jan 29, 2004
sunilr's Avatar
sunilr is an unknown quantity at this point
Couldn't rest the "Maintenance Required" light even after following the instructions given on page 64 of Owners manual. This a pretty new car (2002 Coupe LX) with 15000 miles and doing regular oil changes for every 3000 miles.
But one thing is that I have installed Injen Cooled air Intake and it use to blink for 10 times earlier and now suddenly the Maintenance light is always lit.
Any help is greatly appreciated
Old Jan 30, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
Do you have the reset button pushed in, before you even turn the key to the ON position (and keeping the button pushed in for at least 10 seconds) ?
Old Jan 30, 2004
robbclark1's Avatar
Retired suspension supermod.
just keep holding it. It should shut off.
Old Jan 30, 2004
mrb420's Avatar
mrb420 is an unknown quantity at this point
yeah what they said.
i do it all the time
always works.
Old Jan 30, 2004
sunilr's Avatar
yes i did hold on the reset button b4 putting the keys and then turned on the ignition and waited for more than 10secs and nothing worked .
Old Jan 30, 2004
FALKEN's Avatar
Civicforums Junkie
this should be locked...it has been covered and detailed countless times
Old Jan 30, 2004
Ronin's Avatar
Yeah, I know... but the reason I didn't lock it right away was because I wanted to find out if he was doing it correctly. Seems like he's doing it right ... so it might be an actual bug in his car.
Old Jan 30, 2004
FALKEN's Avatar
Civicforums Junkie
ok then...please post your steps in attempting to reset
Old Jan 30, 2004
sunilr's Avatar
Steps I followed are like these.
1. First thing I do is press the reset button and hold it
2. Then put the ignition key and turn it to position II and keep holding the reset button.
3. wait for more then 30 seconds.
Nothing happens
Old Jan 30, 2004
FALKEN's Avatar
Civicforums Junkie
*make sure that your odometer is in the odometer position (not in trip A or B)*
insert key with right hand
press reset button (and hold)
turn key to #2 position
(keep holding the reset button)
takes 7-10 seconds for 'most' of the dash lights to turn off
when they do...turn the key back to the #0 position
release the reset button and start the motor...
gone now??
Old Jan 30, 2004
AZ2K1Civic's Avatar
When I reset mine Ive been holding it and then starting the car...worked every time
Old Jan 30, 2004
sunilr's Avatar
It was in odometer position. But, I again changed the cdometer position from odometer position to Trip A to Trip B and back to Odometer position and then repeated the process. This time it worked...
Thanks Falken for ur suggestion.
Old Jan 30, 2004
FALKEN's Avatar
Civicforums Junkie
your welcome
Old Jan 30, 2004
robbclark1's Avatar
Falken OWNZ!!
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Blazz
May 25, 2015 10:56 PM
oneqwkfbody
Nov 18, 2001 08:04 PM
