Starting issues
Old Dec 18, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Starting issues
Once again, I just don't get it. It doesn't make any damn sense. My car has trouble starting, but it isn't the first start of the morning, nor is it really a cold start. After I drive somewhere, and the car sits for a little while (anywhere from 20 min- 2hrs), it seems to have difficulty starting. The starter cranks, but just won't fire. After 3 or 4 tries, it will stumble, then slooooooowly come to life. Almost seems like theres water in the lines, but I just put new gas in it (so its now happened with 2 tanks of gas from different stations, dumped dry gas in, still no luck. But the gas shouldn't be bad anyways, it hasn't sat for long. I don't think its an ignition issue though, once the car is running, it runs like a top. So WTF????? Once again this car makes no friggin sense!
Old Dec 19, 2003
flotsamm's Avatar
If you take the key out, then try again does it start? Mine does this occassionally also. But if it doesnt start after a couple of seconds all I do is take the key out and re-insert it, wait the Immobilzer light to go off then it starts right up 99% of the time.
Old Dec 19, 2003
Jap-Euro Fusion
I never tried that... you think the immobilizer is going screwy? What the heck would cause that?
Old Dec 22, 2003
Quiksilver09's Avatar
Quiksilver09 is an unknown quantity at this point
I had to take my car back and get the key replaced because something was screwed up with the chip, don't know if it might be the same thing for you.
-Nic
Old Jan 2, 2004
hachiroku's Avatar
hachiroku is an unknown quantity at this point
I've heard that just the key getting wet affects the immobilizer.
Old Jan 3, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
I'm sure you know this, but are you turning the key way too fast? I usually wait for the "maintenance required" light to go out 1st or when I finish hearing the noise (I think it's the fuel sensor thingy) then I turn the car on. My dealer never said to do that, but the dealer where my mom got her Odyssey, they said to do that. And I havent had much problems since.....
Old Jan 4, 2004
HondaLuver's Avatar
Its a celebration bitches!
it could be the battery, u might have killed some cells, it takes a few cranks now for mine to start, i knowo i have like 1 cell thats working, im waiting on my yellow top battery it should fix the prooblem...
Old Jan 4, 2004
flotsamm's Avatar
I think its Immobilzer related, atleast for my car when it doesnt start normally. When ever it takes longer then normal, the green Immoiblizer light is flashing. I remove the key, wait a few seconds and try again. Usually it starts right up.
ayoitzjulesdx98
May 13, 2015 08:31 PM
jetcare101
May 8, 2015 01:33 PM
civic_gt
Apr 19, 2015 08:15 AM
black2k1vtec
Dec 6, 2001 09:49 PM
