will my endlinks break
ok, ive tried to loosen my endlink bolts because i got the rsx sway bar....i couldnt do it but i borrowed a pipe from my friend to put over the allen wrench for more leverage and i guess i loosened the bolt a little bit, if i shake the sway bar the feel that is is a little loose on the side i was tryign to loosen. when i drive it makes a creaking/pounding noise, will my endlinks break, i just got no time to take care of it and i tired tightening it back, but i cant! lol,
If its loose, it won't break, but the sway bar is useless because you didn't put any tension on it. My guess is you busted something, I think a new end link is about $20.... just get another one. It'll cost you more to take it to Honda to look at it. But before you do anything, get back under there, take the nut off, make sure you didn't cross thread it, try to put it back on and tighten it, if you can, great, if not, order an endlink.
Touge
Sep 22, 2015 11:55 PM
Touge
Ottawa
Sep 22, 2015 11:52 PM
Touge
curaze
Sep 22, 2015 08:27 AM
Bikergofast
Sep 12, 2015 10:54 AM
