Bunch a problems
Old Oct 12, 2003
Xerxes3333's Avatar
Xerxes3333 is an unknown quantity at this point
Bunch a problems
If anyone has any suggestions on these, it would be greatly appreciated. The last guy that had my car totally screwed it up.
The front right speaker does not work, I believe it needs to be re-grounded. Is there an easy way to re-run the ground wires?
The passenger window does not roll down on the passenger side because again something is wrong with the wires. I have taken the door panel off and looked and the wires look fine to be, so I don't know what is going on with that. I can roll it down from the driver's side.
Also, the windows take forever to roll down. It has to either be a wiring problem or a window motor problem.
The glovebox makes an annoying squeaking sound when I go over bumps.
The back seat pops up on the left side. I can try to glue it down, but I don't know if there is a way to order a clip for it or something.
It is also dented on the roof and pasanger door a bit. And I am sure that is gonna cost a lot to fix.
I really appreciate your help, guys! I know my car is a piece, but I am trying to make it better.
Patrick
Old Oct 12, 2003
flotsamm's Avatar
I dont think there is an easy way to re-run the speaker wire from the head unit without pulling off panels and such. Perhaps try using an ohmmeter and do a continuity check to see if the wires are good.
If the window wiring is wrong or the window regulator isnt working right, then it can make the window roll down slow. BTW the window regulator is the whole scissor assembly, not an electrical device as some would think. Sometimes you can remove the motor and then see if if the winow moves up and down freely. If it doesnt then you have to troubleshoot where its getting stuck at.
Old Oct 12, 2003
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
You don't have the pssenger window lock out button pushed by mistake, do you? Also some people suggest a little parrafin wax on the window edges to make them slide easier.
Old Oct 12, 2003
Xerxes3333's Avatar
lol. I do have a window lock button, but it is not on. I have checked several times. If it was on, I wouldn't be able to roll it down from the driver's side either. I don't know how much the wax would help, because I have had the door panel totally off and it is still about half as fast as it should be.
Old Oct 13, 2003
tinman's Avatar
Well, if you can roll it down from the drivers side, I'd take a close look at the passenger side switch itself.
The wax goes into the weatherstrip groove that the window runs up and down in. Teflon spray works as well. The door panel has nothing to do with it.
Old Oct 13, 2003
Xerxes3333's Avatar
Do you mean the window switch or the window lock switch? I have replaced the window switch with a new one and that did not fix the problem, unfortunatly.
Old Oct 13, 2003
tinman's Avatar
Oh, as to the button......
I once proceeded to remove my starter (different car) in the morning trying to figure out why it would not turn. 2 hours later I noticed that the night before, I left the car in "D" when I parked. Needless to say I felt like a total idiot. It happens... LOL
Old Oct 13, 2003
tinman's Avatar
Coupe or sedan? I can have a look in the service manual for you.
Old Oct 13, 2003
Xerxes3333's Avatar
It's a 99 coupe, so I dunno if that will work. Like I said the last guy screwed up all the wires on the right door. I would like to find the guy and personally kick his a$$.
Old Oct 13, 2003
tinman's Avatar
Ohhh...... Nope. Wrong manual. My guess is that you have a pinched or cut wire going through the door itself. Most likely a ground.
Sorry I can't help you beyond that.
sharp66
31
Jun 12, 2022 08:45 AM
autowill
May 15, 2015 11:36 AM
nontypical
May 4, 2015 04:10 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
