Slipping Clutch
Old Aug 9, 2003
dustin_samuel's Avatar
dustin_samuel is an unknown quantity at this point
Slipping Clutch
Don't know if this is normal becuase this is my first manual car, but when I hit little bumps, dips, flat railroad tracks (stuff that's not hard on my suspension), my clutch seems to slip while in gear at high rpm's. It's kind of hard to explain. Any thoughts or experiences?
Old Aug 9, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Are you sure the dips aren't causing a wheel to come up a little to freely spin? You can tell if that's the problem, because RPMs will go a little higher, but immediately drop back to normal after the bump. If the clutch was slipping, they would go up, level off, and drop back down... pretty much in a smooth motion.
Whitexj
Sep 30, 2015 02:04 AM
Michael Durkin
Transmission
Sep 24, 2015 12:35 PM
powman02
Sep 15, 2015 07:38 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
Klame9420
Sep 7, 2015 10:03 PM
