Electrical Post information/questions/Issues about Electric parts here.
20063 Civic electrical issues
Old Apr 27, 2022
kasha33's Avatar
kasha33 is an unknown quantity at this point
Had to jump start the car, and now it has some electrical issues. The radio does not work at all, no display. The remote lock/unlock does not work. Interior lights are not activated by the doors being open, no matter what position the light switch is in.
So, for my question - I am not familiar enough with the ECM/ECU/PCU to know which one/ones are causing the issues. I would like to pull the faulty item, or items, out of the car and send off for a repair, if possible. Is there any reasonable way to figure out what I need to pull and send?
Thank you!!
dave
Old Apr 27, 2022
BrotatoChip's Avatar
Super Moderator
Re: 20063 Civic electrical issues
Check the battery voltage when the engine is on/off.
Old Apr 27, 2022
kasha33's Avatar
OK, I can do that. What will that tell me, or what should I do with that information?
Old Apr 27, 2022
CraigW's Avatar
Was, any reverse polarity events involved in the matter ??
Old Apr 27, 2022
kasha33's Avatar
No, none. I have heard that this particular year/model is a bit sensitive to being jumped, even when done correctly.
Old Apr 27, 2022
kasha33's Avatar
Is anyone familiar with MICU in the 2006 Civic? I have a suspicion that may be the issue. I am trying to figure out if anyone has the ability to repair it, like a ECM/PCU.
dave
Old Apr 28, 2022
Super Moderator
My first thought was bad alternator wasn't charging the battery which is now dead causing electrical issues. Could also be blown fuses. Both of these are easy to check before you start buying replacement parts.
4fasho
Electronics
Mar 18, 2022 05:15 PM
RJII
Electrical
Jan 4, 2021 09:16 AM
beamer_01
Exterior
20
Oct 3, 2017 11:26 AM
OneJzSupra
Jun 14, 2014 05:27 PM
