Electrical Post information/questions/Issues about Electric parts here.
Damaged Alternator Connector
Old Aug 13, 2021
Burton80709's Avatar
Burton80709 is an unknown quantity at this point
Can you post some pics? I don't understand what you mean.
That pressure switch should have one wire going to it. The sensor itself is grounded through the block. When oil pressure is low the switch closes applying that ground to your yellow/red wire. Are you saying you have the wire on the sensor side but don't know where it goes on the harness side?
I actually need help really bad, I have a 2011 civic 1.8, the wire harness for the alternator was ripped out, I have a new one but have no idea which wires go to which pin
Old Aug 13, 2021
BrotatoChip's Avatar
Super Moderator
Re: Damaged Alternator Connector
Please don't reply to other unrelated threads with you issue....
This is what I could find in the '06 service manual.
Old Aug 14, 2021
Alternator wiring harness issue
Ok so I have a 2011 Honda Civic 1.8.. the car was given to me by my girlfriends aunt which she got mad a ripped a bunch of wires out so her daughter couldn’t use it… well she ripped the 4 wire harness out from the alternator, I ordered a new one from eBay and none of the colors are the same and I cannot find anything that can help me match these wires up to the new harness. I basically need to see someone’s harness on their car to match up to make sure these are correct
Old Aug 17, 2021
Super Moderator
I will literally cry if twisting a wire around a terminal is how you plan on fixing this.
I gave you the wire color and pin location in my previous reply. Connector pins should be numbered somewhere.
Old Aug 17, 2021
I was thinking that it was just for pin matching purposes.
Old Aug 17, 2021
Super Moderator
I certainly hope so!
Old Aug 17, 2021
that’s exactly what it was for, you must know some savage people if you imply Iam gonna drive down the road like this
Old Aug 17, 2021
a diagram was sent yes , which I followed, old alternator was shot, I put a remanufactured one in and now it’s getting extremely hot
Old Jul 21, 2022
Mick gee's Avatar
Mick gee is an unknown quantity at this point
Hey hello did you get to the bottom of this ? A garage changed out my alternator on my 2007 and the one they put in was getting so hot it was melting the paint of the alternator body, then it starter over charging. They then again put another in same brand Lucas I think but it started getting hot and over charging once again.
I am waiting for a Bosch version to arrive today to see if it fixes the problem, in an preempt start to problem solving wanted to see if you got to the bottom of your issue ?
Old Jul 21, 2022
Colin42's Avatar
These cars dont like aftermarket alternators, a used one from a junkyard would be better
gts
Oct 21, 2017 05:05 PM
JMKendrick
Sep 16, 2015 06:17 PM
Thaik
19
Feb 2, 2014 11:03 PM
Rupert
Dec 1, 2011 05:15 AM
myoldcivic
Apr 2, 2010 11:03 PM
