Electrical Post information/questions/Issues about Electric parts here.
Head Unit and Gas Gauge won’t turn on
Old Apr 3, 2020
UrDeadBf's Avatar
UrDeadBf is an unknown quantity at this point
Hi i have a 2007 civic si. Last night when i was driving home i was coming up my street in first gear and the car seemed to die for a second. When i opened my door none of the lights turned on or anything but then when i put my key into the ignition everything started up but my head unit won’t turn on and my gas gauge is just showing empty. I disconnected the battery and put it back to see if that would reset it but it did nothing. I let the car start up and run for a second as well and nothing too. Did I blow a fuze or something shorting. Please help thank you!!
Old Apr 3, 2020
mac25's Avatar
Dr Krieger of Modification
Re: Head Unit and Gas Gauge won’t turn on
Might be a dying alternator. When they go some of the electronics will run, others fail.
Start the car and test the voltage. It should be 2 volts above what the battery reads while the car is off. Ideally 14v running, 12v off.
other than that, I'd start by checking all fuses, a test light helps speed things up. Also check for signs of rodents, which could have chewed into the wiring.
Greenmonster
Dec 1, 2015 03:10 PM
cobhc_log
Jul 15, 2014 09:12 AM
Marktg83
Nov 28, 2013 07:27 PM
americanlt
Feb 10, 2012 03:43 PM
remborsky1
Aug 30, 2011 07:05 AM
