Stereo Problem
Old Nov 18, 2015
Greenmonster's Avatar
Greenmonster is an unknown quantity at this point
Stereo Problem
Hey All,
I have an aftermarket head unit installed and it has been working flawlessly for the past 3 years now however, just recently when I turn it up to a louder volume it keeps cutting in and out on me. I have noticed that its the entire system itself including the head unit, all four speakers, and the sub; they all turn on and off when I turn it to a louder volume. Could it be because the head unit itself is really old? It's about 5 years old, or a power situation, I only noticed it happening after I replaced my battery with a brand new one. Any advise would be awesome.
Thank You
Old Nov 18, 2015
Mad Dog Tannen's Avatar
Re: Stereo Problem
Check your battery cables and everything that attaches to it. clean off the connections and replace the cables if necessary. It sounds like a bad connection to your battery.
Old Nov 18, 2015
Re: Stereo Problem
Hey
Thanks for the response, if there were a bad connection to the battery wouldn't the car not start? I installed the head unit myself and never even had to go near the battery for installation other than making sure it was disconnected so I didn't get shocked. I'm not convinced it's a bad connection....
Old Nov 18, 2015
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: Stereo Problem
Sounds like an issue in the power chip in the head unit. It may be getting hot and shutting down. Does it come back on after a few minutes or do you have to shut off the car and restart it?
If it comes back on only after a shut off and restart of the car, how quickly does that happen? Can you replicate it on demand, or does it take time after the head unit has been turned up?
Is the head unit shutting completely off, or just losing sound?
Old Dec 1, 2015
Re: Stereo Problem
It's actually just the sound that cuts off the head unit stays on. It doesn't cutoff permanently either it just keeps tuning in and out when the volume is up.
Old Dec 1, 2015
TiggerDX's Avatar
Re: Stereo Problem
Sounds like one of the speaker wires is grounding out. Follow the wiring and see if it is pinched or cut anywhere, especially in the doors.
Aznman007
16
Aug 22, 2009 11:54 AM
civic02ex
Jul 1, 2004 10:49 PM
