DRL Instrument panel light
Old Nov 30, 2015
shaejb15's Avatar
shaejb15 is an unknown quantity at this point
Hey Guys,
I've been having some DRL issues so I just pulled the fuse as I am getting seperate lights. Problem is the DRL light on the instrument panel stays on... Is there any way of waiving it off? Thanks
Old Nov 30, 2015
mac25's Avatar
Dr Krieger of Modification
Re: DRL Instrument panel light
why did you pull the fuse, what were the issues?
Old Nov 30, 2015
shaejb15's Avatar
Aftermarket LED's screwed something up. Getting seperate daytime philips lights. Does anyone know how to waive the DRL light off the panel? Thx
Old Dec 1, 2015
mac25's Avatar
This is important! You should always state any mods to the system.
There is a DRL relay which cuts power to the circuit if a bulb is burnt out (or if the relay thinks the bulb is burnt out).
LED's create far less resistance so the relay cuts power to one of them, look into installing a resistor to boost the resistance of the bulb which does not light up.
Old Dec 1, 2015
shaejb15's Avatar
Thanks for the info. I kindof looked into that but i appreciate you explaining it. I'm going to order a resistor. Will the DRL relay reset it self after I install the resistor? Like will the light work right a way you think? Thx
Old Dec 2, 2015
mac25's Avatar
It should.
Basically a relay has two coils in it and when voltage is allowed to flow through one coil, by electro magnetics it causes the other coil to push electrons. (If you're interested look into Faraday's law).
So granted the relay was working before the LEDs, it should still be functional.
ktae13
Electrical
Sep 26, 2015 05:14 PM
Juanb24
Sep 15, 2015 12:39 AM
aaronmechanx
Sep 14, 2015 08:45 PM
shaejb15
Sep 12, 2015 01:02 AM
NaturalSelectio
Sep 6, 2015 06:59 PM
