Brakes Post information/questions/Issues about Brakes here.
2008 EX: how to compress caliper piston?
Old Nov 5, 2024
gts's Avatar
gts
gts has a spectacular aura aboutgts has a spectacular aura about
For our 2008 Civic EX
I watched a video (1A Auto video) about installing the rear brakes and the guy shows that the caliper's piston needs to be turned/ twisted in like it's a screw to "compress" it.
So I tried screwing the piston in using but it just spins. Any ideas on what to do to get it to screw in?
Old Nov 5, 2024
Re: 2008 EX: how to compress caliper piston?
Had to deal with this on my friend's 08. Push in with a bit of force and turn like a screw worked for me.
Old Nov 5, 2024
Colin42's Avatar
They make tools to make it easier
Old Nov 6, 2024
gts's Avatar
gts
Thanks guys.
I figured this out after finding the tool I have for screwing in the caliper. It allowed me to use more force.
Initially I used a flat bar which fit in the slot but apparently I wasn't using enough pressure.
The odd thing about the two calipers was one screwed in relatively easy.
The other didn't seem to be screwing in even though it was.
The amount it went in with each turn seemed to be very small which gave me the impression it wasn't screwing in.
Probably because it wasn't going in as easily (thus faster) as the other.
Thanks. I found the tool I use.
It'd been a long while since changing pads on a caliper that needed the piston screwed in.
Forgot I had it until I looked into buying a tool and realized "wait a minute I have one of those" (the square one fits on a 3/8" ratchet).
Thanks again
Srikanth.chepur
Nov 23, 2010 10:57 PM
Srikanth.chepur
Air Conditioning
Nov 23, 2010 02:43 PM
Markos14
Nov 15, 2008 01:14 AM
