Bearing replacement
Old Nov 30, 2024
Nebular's Avatar
Nebular is an unknown quantity at this point
Bearing replacement
I'm going to be taking on the project of replacing a bearing in my front left wheel. Been getting the airplane noise that seems to be originating from the front left side typical of bearing failure. I have had bearings fail before (driving on the beach will do this to you), but now I'm ambitious enough to want to do this myself as this is probably something I should become familiar with in this sandy and wet area.
What is the recommended course of action? Change bearing and hub? Or just the bearing? Can I rent the tool and do it all myself or should I have it pressed in at the shop? Any part recommendations?
Stats:
2012 EX Civ Coup
130,000
Old Nov 30, 2024
Colin42's Avatar
Re: Bearing replacement
I'd do the bearing and hub.
not to bad to do yourself, or just bring the knuckle to a shop, they'll do it for you pretty cheap
Old Dec 1, 2024
Nebular's Avatar
appreciate the replies on both my threads lol. As far as kits, what do I need to remove the knuckle?
If I wanted to do the whole job, I'd need one kit to separate the hub, and one kit to put it back? I'm a little confused as to what I need.
Old Dec 1, 2024
Colin42's Avatar
Silde hammer to pull the hub, bearing puller to remove the old bearing and install the new bearing and hub
Old Dec 18, 2024
Nebular's Avatar
So I figured I'd reply to this original thread. I changed out the bearing, but it didn't do much to stop the noise Completely (albeit the bearing was indeed bad) The sound is a woohing almost helicopterish sound, and is noticeably louder on the driver side front than the passenger side. Can this be the CV shaft? I looked into the differential, but this car does not have one separate from the trans. Also no driveshaft...I know that there are bearings inside the CV shaft that could go bad as well. Any ideas? I may pay a shop to diagnose the issue before I throw another $100 at solving a problem I don't have.
Old Dec 18, 2024
Nebular's Avatar
Here is a clip of the sound. It's most notable at 30mph and 45mph. Sort of like an undulating helicopter sound, but quick. Obviously inside the car, the sound is much more pronounce.
Old Feb 10, 2025
chuffsy's Avatar
chuffsy is an unknown quantity at this point
Nebular, did you resolve the sound issue? If not try rotating tires. Please report back
AMartin25
Jan 17, 2017 06:45 PM
lame05
Transmission DIY
Sep 8, 2013 02:25 PM
BlueEM2
May 21, 2013 08:03 AM
lobomic
May 8, 2008 01:23 AM
ryangt
South Cali
23
Dec 20, 2006 09:30 PM
