Noise from bottom of civic 2012
Rep Power: 0 Noise from bottom of civic 2012
I have a civic 2012, 250Km. when I drive, if the road is uneven, I can hear noises from the bottom. Sounds like being caused by bad engine and transmission mounts. I changed all mounts, control arms, cv axles as well. The phenomenon still exists. I hold the side of axles connecting to the transmission case and shake, I can shake them. When I installed the new axles, I put my finger into the case, I can feel the bearing is loose, I can shake it. Is it caused by a possibly bad bearing? In case I need to replace the bearings, do I need to disassemble the whole transmission case? It would be a big job. I appreciate very much your opinion and help.
Received 1,156 Likes
Rep Power: 485 Re: Noise from bottom of civic 2012
gonna have to be a bit more specific with what kinda noise it is. Rumbling that changes with vehicle speed? Tapping that changes with RPMs? Squealing? Whining that sounds reminiscent of a supercharger doing its thing? Any increase in NVH all around? Any evidence of rubber deterioration in the aforementioned mounts?
Rep Power: 0 Re: Noise from bottom of civic 2012
Jmccracken
04-04-2019 09:03 AM
Civic3000
08-16-2013 02:43 PM
