2012 Civic si Transmission Problem
Old Jan 23, 2018
ykf7b0's Avatar
ykf7b0 is an unknown quantity at this point
Our 2012 Civic si manual 6 speed has become really hard to shift into gear. We recently had record low temperatures with sleet and snow in the area. The car sat for 6 days and it was at this point the shifting issue began. The temperatures have warmed up since but the shifting issue remains. The clutch fluid reservoir is full and the shifting seems to get some better once we get it going. What should I be looking at to remedy the issue?
Old Jan 25, 2018
mac25's Avatar
Dr Krieger of Modification
Re: 2012 Civic si Transmission Problem
check the fluid first, level and condition.
Old Jan 26, 2018
Kinda vague description, so....
Inspect shift cables and linkages for wear and operation (maybe mice built a nest on top of your transmission or something)
Check more into clutch and/or disc issues. Decide if the problem is actually related to a clutch mechanical or hydraulic problem instead of an internal transmission problem.
Replace fluid first (use Hondas manual trans fluid) and try it out before deciding to take the trans out for major work.
Old Jan 26, 2018
ykf7b0's Avatar
Thanks for your responses! It was a real easy fix. Even though it was hard to notice, the floor mat had wrinkled up under the clutch pedal a little and not allowing enough travel.
Old Feb 6, 2018
ykf7b0's Avatar
Well the mat under the clutch pedal turned out to be wishful thinking. I have since changed the transmission fluid with Honda brand fluid and bled the slave cylinder numerous times. The problem is intermittent and it always involves low speed forward gears and reverse. Any more ideas before I take it in to the stealership?
Old Feb 6, 2018
Still too vague, I can't understand your complaint yet--or at least it's not yet clear enough to draw a mental picture of what it does or doesn't do when it acts up.
Is the clutch not disengaging completely when you push the pedal down?
How many miles on the car?
Ever had a clutch job done on it?
How much free play is in the pedal link?
How close to the floor does the clutch start to engage?
Old Feb 6, 2018
ykf7b0's Avatar
The transmission is hard or impossible to engage into 1st and/or reverse at times. It does fine for a few days after bleeding the slave cylinder but problem returns. I see no signs of leaking and the reservoir is always full. 130k on the car with no previous work performed. Play is minimum in pedal and all travel is normal regarding pedal. Seems to me the problem is hydraulic but not sure if its within the slave or master cylinder. Thanks!
Old Feb 7, 2018
See if the rubber boot on the slave cylinder has fluid trapped in it?
I mean the round boot on the slave itself, not the larger boot that covers the throwout fork and the hole in the side of the trans
Old Feb 8, 2018
ykf7b0's Avatar
No leaks. I'm going to try the easier and cheaper things first and start with replacing the slave even though it's not leaking. It's not the norm but I have been reading instances where they were faulty but not leaking. Pulling the trans will be the last resort.
Old Feb 10, 2018
Boosted Turtle's Avatar
Boosted Turtle is an unknown quantity at this point
Try changing out the slave cylinder and see what happens. hopefully it can be that the slave has gone bad.
kingrat
Dec 9, 2015 05:34 PM
Biggunschad
Sep 11, 2015 04:06 PM
KyprosEc
Feb 10, 2014 07:22 AM
OhioIsOnFire1
Nov 23, 2013 09:26 PM
WICKEDPHOTO
North East
Mar 11, 2012 11:59 PM
