Po717
Old Feb 5, 2011
rotndawg's Avatar
rotndawg is an unknown quantity at this point
Po717
I have an 07 civic auto with 140kms that has a transmission code for the turbine speed sensor input, the car clunks hard when shifted into drive or reverse and takes a long time to shift into high gear. Has anyone replaced this sensor? where is it? internal or external ? or should I just drop another trans in it, $800 for a low millage trany from a junkyard.
Thanks in advance for any advice or help.
Old Feb 5, 2011
lazlong's Avatar
Re: Po717
The service manual says that code is electrical NOT mechanical so, replacing the tranny will do no good. The sensor should be right on top of the tranny, it's a 2P connector. Check the fit and if it's ok then ohm it out. You should get 400-600 ohms. If you don't get 400-600 ohms then replace the sensor.
Old Feb 5, 2011
rotndawg's Avatar
Re: Po717
Thanks for the info, I think i solved my problem, i changed the trans fluid a couple times and the code hasnt come back and it now shifts great. I guess i should pay more attention to maintaince schedules.
Old Feb 6, 2011
lazlong's Avatar
Re: Po717
lol. We've all done it. Lesson learned. Good thing it wasn't too costly.
carlosdee
Sep 12, 2014 10:48 PM
