2007 Honda civic help pls?
Old Jun 5, 2023
Dannyc's Avatar
Dannyc is an unknown quantity at this point
2007 Honda civic ex Manuel car is in limp mode no code are being thrown I have replaced the fuel pump the fuel pump relay top and bottom O2 sensor car only has a short ram intake car will not rev passed 4rmp have also replaced the VTEC solenoid ignition coils spark plugs can some one please help ?!?!
Old Jun 5, 2023
Colin42's Avatar
Re: 2007 Honda civic help pls?
What codes are you getting?
What brand are the parts you installed?
Old Jun 5, 2023
Dannyc's Avatar
I'm getting no codes and I replace the part with dorman OEM v tec solenoid OEM parts car came with short ram kn intake and magnaflow exhaust
Old Jun 5, 2023
Dannyc's Avatar
Car 5 spd manual won't rev past 4,000 rpm
Has ngk spark plugs and coils
Old Jun 5, 2023
Colin42's Avatar
Dorman is not oem.
What brand were the o2 sensors?
Old Jun 5, 2023
Dannyc's Avatar
Bosh and ntk
Old Jun 5, 2023
Colin42's Avatar
Cant use bosch, need to be denso or sometimes ntk works.
Old Jun 5, 2023
Dannyc's Avatar
Sorry they are denso
Old Jun 6, 2023
If your car is in limp mode, it would almost certainly be throwing a code with the check engine light on. You've hooked up an OBD reader (or gone to an auto parts store) and had them scan the ECU for stored codes?
Old Jun 7, 2023
Dannyc's Avatar
I have taken the car to three mechanic all said it was different thing one said it one the VTEC solenoid so I replace it other said it the fuel pump I replaced it as well and the other said it my intake but that makes no sense
Oscarjrp
May 10, 2022 01:34 AM
Manasmakkar
General
19
Aug 13, 2019 11:06 AM
ayanow
Nov 5, 2017 07:31 PM
richo778
Jan 6, 2014 05:00 PM
manchester
May 24, 2011 02:25 PM
