How to tell whether spark plugs are original factory installs?
Old Oct 19, 2022
niemand's Avatar
niemand is an unknown quantity at this point
I know that Toyota factories mark the spark plugs. I wonder about Honda. I have come upon a used 2013 Civic EX with 110k miles. I removed the spark plugs for the first time today. The plugs are NGK DILZKR7B11GS. How do they look? I am debating whether to replace them. NGK resistance spec for this spark plug is 5 kΩ. I measured the resistance and tested the continuity. All center electrode continuity with tip tested good. All ground continuity with base tested good. No short between center electrode and ground. Gap for each verified to be at 0.044".
Cylinder 1 plug, measured 4.47 kΩ:
Cylinder 2, measured 3.32 kΩ:
Cylinder 3, measured 4.00 kΩ:
Cylinder 4, measured 3.50 kΩ:
Old Oct 20, 2022
FRSam's Avatar
Click Here
Re: How to tell whether spark plugs are original factory installs?
I mean, they very well could be. 110k miles isn’t crazy for spark plugs anymore. I think my dad finally did the ones on his Focus ST at like 180k miles after buying it brand new.
Old Oct 20, 2022
Colin42's Avatar
You've come this far, just replace them. Never heard of anyone measuring spark plug resistance before.
Old Oct 20, 2022
Harry Hemi's Avatar
Harry Hemi is an unknown quantity at this point
Isnt NGK aftermarket plugs? Arent Denso the factory plugs? If youre going to replace them, use the original equipment, which I would think is Denso.
Old Oct 20, 2022
niemand's Avatar
Both are:
Old Oct 20, 2022
FRSam's Avatar
Click Here
Originally Posted by niemand
Both are:
Can confirm. This is the case with pretty much every Honda.
Old Oct 25, 2022
niemand's Avatar
Per Lela Martin, Technical Support of Aftermarket Division at NGK U.S.A.: "Resistance value between 3,500 ~ 7,000 is within specifications because the resistance value of the plug does not determine the performance at all. The resistance is only there to eliminate electronic frequency interference."
I also inquired about the gaps being narrower than spec'd on some new plugs I bought. Her response: '.004” will not make any difference on the performance. It is actually better to be on the lower side since the gap will wear up.'
EarleD
Jul 24, 2019 08:04 AM
ubnpast
Mar 25, 2012 08:35 AM
ubnpast
Mar 23, 2012 09:30 AM
LT2004ever
Electrical DIY
95
Mar 10, 2012 04:59 PM
zen_master
54
Jul 22, 2005 03:00 PM
