Trying to identify coolant Leak
Old Oct 3, 2022
Caltron3030's Avatar
Caltron3030 is an unknown quantity at this point
Hello, I've been chasing a coolant leak for awhile. Seems to be worse on the driver side. I don't know **** about cars so I'm sorry if this isn't enough info.
It's a 2010 Honda Civic LX Coupe
Any ideas? I feel like it's the radiator.
Checked the oil and it's clear. Also nothing white and thick or evident coming out of exhaust.
Under the battery is where the worst of it is
Old Oct 3, 2022
Re: Trying to identify coolant Leak
I can also see coolant at the very bottom of radiator fins and on the right side fan.
Old Oct 3, 2022
Colin42's Avatar
Could be the rad, can't remember if the 2010s had the block cracking issue
Old Oct 3, 2022
I've scoured through tons of forums and it appears to be up until 2009 models. I guess I just need to get a pressure test
Old Oct 3, 2022
cracked block is in the back side of engine, between firewall and engine
Old Oct 3, 2022
can I ask what makes you think that is it? Why is there a bunch of coolant in the radiator then?
thanks for the reply
Old Oct 3, 2022
why do you think you have a cracked block instead of something different?
now, correction on my part: it is in the front side.
https://www.civicforums.com/forums/3...locations.html
Old Oct 3, 2022
I’m sorry, I thought you were stating that my problem is a cracked engine block. I think I misread what you were saying
Old Oct 3, 2022
Old Oct 4, 2022
BrotatoChip's Avatar
Super Moderator
Are you able to figure anything out from underneath? Why the aftermarket rad cap? Is it the cause of the leak? Check the small hose going to the reservoir, it could have a slow leak as well.
Old Oct 4, 2022
I just bought it to replace the old radiator cap, just to rule out that being the problem. That was the only one they had available.
I got underneath and I’m having a hard time finding the leak
Old Oct 4, 2022
Colin42's Avatar
Fan shroud will be blocking it if it's the rad that's leaking. Or the plastic splash shield.
Old Oct 8, 2022
OKay, so I rented a pressure tester from O'Reillys and still cannot find a damn leak. The PSI went down super slow over 20-30 min and then stayed put around 15 PSI.
I'm scratchin my head here.
Old Oct 9, 2022
Colin42's Avatar
Looked here yet?
Old Oct 9, 2022
Looked here yet?
Jdawg1
Jun 20, 2022 06:42 AM
Tristinn Davis
Jul 26, 2020 08:44 PM
brenden.bruce
Oct 30, 2013 11:38 PM
BombSquad91
Jul 16, 2011 02:04 AM
d0ubi
Jan 19, 2010 04:25 PM
