Excessive fuel consumption?
Old May 27, 2022
Shepard's Avatar
Shepard is an unknown quantity at this point
Hi everyone, this is my first post here, though I’ve been reading for quite a while. I’m kind of concerned for the fuel consumption I’ve been getting from my Honda Civic. It’s a 2010 EX 1.8 automatic, with 60.000 miles. It’s never been really economical, but now it’s averaging like 14MPG in the city. Driving style is not aggressive whatsoever. Just did full maintenance (replaced spark plugs, changed oil and filters, cleaned injectors, checked brakes, etc) but it didn’t improve. Is this normal? What else should I check? Thanks
Old May 27, 2022
Re: Excessive fuel consumption?
o2 sensor
oem one
Old May 27, 2022
Shepard's Avatar
Originally Posted by sdaidoji
o2 sensor
oem one
Thanks a lot. Should I have it checked, or just replace it?
Old May 28, 2022
Colin42's Avatar
At this point you should probably just replace it. It's the primary one in front of the cat you want to replace. The oe supplier is either Denso or ntk
Old May 28, 2022
Shepard's Avatar
Thank you. I read that faulty o2 sensors usually cause other symptoms, such as emissions, gas smell, problems during idling, etc. I’m my case the only one is the poor fuel efficiency. Could it still be caused by the o2 sensor? Any other things I should check?
Old May 28, 2022
at 60k, i would change the sensor and go from there
Old May 28, 2022
Colin42's Avatar
It's not necessarily faulty, just when they get older they don't respond as fast and can cause increased fuel consumption
Old May 28, 2022
Shepard's Avatar
Thanks again. Bosch o2 sensors are a lot easier to get where I live, do you have any references of them? I could also buy Denso, but it would take longer to get the part
Old May 28, 2022
Colin42's Avatar
Do not put Bosch in a Honda. Put in Denso.
Old May 28, 2022
most likely you are going to return the bosch, slow is faster
Old May 28, 2022
Shepard's Avatar
Sorry to bother you again. I’m a bit confused with the position/name of these sensors. I’ve read sellers called them “front sensor”, “rear sensor”, “upstream”, “downstream”. I gather there is one close to the engine and the other closer to the exhaust. Front and upstream should refer to the same part? Do I need to change both, or just the front one? I also read replacing just one could cause error codes, is this correct? Thanks both for your time
Old May 28, 2022
Colin42's Avatar
Front/upstream is the one you want, the rear/downstream sensor just checks that the cat is working
Old Jun 5, 2022
Shepard's Avatar
Hello again. I’ve had quite a bit of trouble finding the correct part. According to Amazon, this NTK is compatible, unfortunately it seems there is nobody to contact in order to confirm
Sensor de oxígeno NTK 24048 https://a.co/d/8wVy5y8
Also, I found this Denso on EBay. I’ve contacted the seller and according to the specs of my Civic, this should be the right part
https://www.ebay.com/itm/12390469184...mis&media=COPY
Unfortunately I have to import the accessory, since it’s not available in my country for a fair price, that’s why I really want to make sure before buying. Thanks for your help
Old Jun 6, 2022
ah, chile...
Do you have honda dealers there? Get whatever the OEM one is
I think chile cars might be made in Brazil?
Old Jun 6, 2022
Shepard's Avatar
ah, chile...
The dealer here charges over 300 dollars just for the part, I think that is excessive, or maybe I don’t know much about the topic. My car was manufactured in USA according to the information on the interior part of the driver’s door
Old Jun 6, 2022
sounds right price... a 2003-2005 wideband sensor is around that too
Old Jul 21, 2022
Shepard's Avatar
Hi again. I bought the original Denso o2 sensor and installed it. Fuel consumption is almost exactly the same as before. What else should I check? Is 14 MPG common for a 1.8 automatic Civic?
Old Jul 22, 2022
Colin42's Avatar
Driving habits, dragging brakes, low tire pressure
Old Jul 22, 2022
BrotatoChip's Avatar
Super Moderator
Other maintenance items like air filter and spark plugs. Maybe the IAT, ECT, or MAP are reading incorrectly. Possibly the ECU is faulty.
Old Jul 22, 2022
Shepard's Avatar
I’ll check the possible dragging brakes. I usually drive in grandma mode and the pressure is fine. Thanks
Shrillcaleb153
Apr 3, 2022 11:58 AM
MSAADM
Jun 22, 2016 03:00 PM
Kerry Emerson
Jan 17, 2016 07:53 PM
chris0628
Jan 7, 2010 01:10 PM
1995hondacivicx
Jul 25, 2007 01:28 PM
