Map Out Warning Light
Old Aug 22, 2019
Senna.ie's Avatar
Senna.ie is an unknown quantity at this point
I've a 2008 civic and a few months ago while doing some work the sump plug hole got cracked and I picked up a used sump to replace it with, problem was this sump came off a civic that didn't have a engine oil senor and so I have to remove it. I've now got a warning light on the dash and that's not really a problem, the problem is my countries national road test requires my car to have no warning lights displayed.
So my question is, is it possible to map out this warning so the warning will be ignored by the brain?
Old Aug 22, 2019
Colin42's Avatar
Re: Map Out Warning Light
no, just put the right part on with the sensor and reset the computer (disconnect the battery)
if the connector has been dangling in the engine bay for a while i'd give it a good clean with electrical contact cleaner
Old Aug 27, 2019
colewan's Avatar
colewan is an unknown quantity at this point
Agreed! My friend had an issue like that an this way solved it!
Doug Lassiter
Jun 26, 2017 02:18 PM
timebombmarie
Aug 9, 2014 05:03 PM
rhvic
Jul 22, 2014 12:58 PM
pnamajck
Apr 21, 2013 11:21 PM
lanevo7
Jun 6, 2010 05:58 PM
