Should I replace my spark plugs
Old Jun 21, 2019
EarleD's Avatar
EarleD is an unknown quantity at this point
My civic has almost 170000 miles. Bought it with 32000 and I haven’t changed them yet. Car runs great. Should I change them? Or maybe just pull them and inspect. Should I use any anti seize if they look good and am just putting them back in
https://shop.advanceautoparts.com/p/...266/11000222-P
I’m pretty sure these are the ones I need.
Thanks again
Old Jun 22, 2019
GolNat's Avatar
Prelude Owner
Re: Should I replace my spark plugs
Yes I would replace to keep combustion optimal. You may not have "issues" at the moment but 100k miles is the typical life from an iridium plug.
I have never used anti seize on plugs personally and I think NGK tells you not to on the box because they already have a coating on them.
Old Jun 22, 2019
EarleD's Avatar
These are the recommended plugs correct. Any thoughts on which brand I should go with. I just got the spark plug socket. So I’m ready to go.
amazon has the oem NGK plugs $25 each. Why are these so much more? Just because it says Honda?
Old Jun 23, 2019
Colin42's Avatar
Go with the ngks
Old Jun 23, 2019
EarleD's Avatar
Just replaced plugs. Went with ngk’s. Super easy. Took 15 minutes.
The old old ones all looked like this:
Glad I did it. They looked pretty rough. Of course with my experience they could be fine. Car stated right up.
Old Jul 24, 2019
colewan's Avatar
colewan is an unknown quantity at this point
Definitely yes
FRCornelis
Apr 7, 2010 12:42 PM
iamboo
15
Nov 1, 2004 11:53 AM
booba5185
Jul 7, 2004 12:15 PM
viciousvolpe
May 23, 2002 12:20 PM
crazyjetskier
Mar 16, 2002 07:22 PM
