07 civic motor mounts
Old Oct 21, 2015
pcpro215's Avatar
pcpro215 is an unknown quantity at this point
Hi all,
Recently, I have been having issue with the car making a loud vibrating type of noise (from passenger side) when starting, and specifically when I shift it to reverse.
I have been doing some research, and it appears that motor mounts are a fairly common issue. In just a quick look, I could only find the top (dog bone) mount on that side.
Is there more than one mount on the passenger side? An upper and a lower perhaps?
f anyone has ever changed these out and would like to give some feedback, it would be appreciated.
Thanks.
Old Oct 21, 2015
Poopies's Avatar
Super Moderator
Re: 07 civic motor mounts
Looks like it's just one mount. Here's the diagram for a 4-door LX 5-speed manual. Your particular setup may vary, so look up your specific model.
http://estore.honda.com/honda/parts/...++47&dl=206925
Old Oct 21, 2015
Word....
https://www.civicforums.com/forums/197-mechanical-problems-vehicle-issues-fix-forum/342963-2008-honda-civic-vibrates-parking-reverse-gear.html#post4577741
Old Oct 21, 2015
pcpro215's Avatar
Yup, I saw it. That's what made me post.
Old Oct 21, 2015
That linked post shows the one that always goes bad and the most common way it fails (collapsed and bottoms out), there's a service bulletin on it that covers a couple different complaints and several years of 8th gens, all because of that one mount.
I just replaced that mount in an 09 Civic coupe late last week for the loud rumble in reverse.
I can try to find a link to the bulletin later on if you need it, but I think I have linked it in posts here before......Search more?
Old Oct 22, 2015
pcpro215's Avatar
Do you happen to know if Honda issued a recall on it?
Old Oct 22, 2015
Poopies's Avatar
Super Moderator
http://owners.honda.com/service-maintenance/recalls
Enter your VIN there.
Old Oct 22, 2015
It is NOT a recall.
Old Oct 23, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
My 07 Motor mount issues..starting about post 19.....
Change out made it fill like new...
Think that lower dogbone rock probably kills that top one. Motor rock is lower one...a heavy buzz at idle in the steering wheel is that upper passenger side one. Use OEM replacements.
see > https://www.civicforums.com/forums/1...ntrol-arm.html
Old Oct 23, 2015
pcpro215's Avatar
That's actually what I checked in on the forum today for; to see if anyone used genuine or after market..
Aren't you also on the hdforums under the same user name?? I'm prplgide there.
Old Oct 23, 2015
RIPSAW's Avatar
I'm the one and the same...ha.. Did you mean prplglide?
Old Oct 23, 2015
pcpro215's Avatar
I did. Nice to see ya man.
671civicLX
Jul 9, 2015 03:22 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
marciano117
Jun 25, 2015 09:06 PM
usajags84
May 30, 2015 06:49 PM
blouisgod
Nov 27, 2001 09:27 PM
